Author Topic: Parts source for CB350F front disc brake  (Read 755 times)
Offline Badger
« on: March 30, 2019, 03:19:23 PM »
Howdy:
My 350F is going to need new front end brake parts, caliper, master cylinder, disc, and hoses.
I am looking for braided stainless brake lines and a nicer looking disc.
Will consider rebuilt master cylinder and caliper.  I am not able to rebuild what is on the bike.
Any sources you folks may have will be appreciated
Best Regards
1973 CB 350 Four
2014 Harley Davidson Electra Glide Limited with the wethead
Online bryanj
Re: Parts source for CB350F front disc brake
« Reply #1 on: March 30, 2019, 03:29:40 PM »
Pattern, decent quality master and caliper at Dave Silver, different disc is not easy and lots of suppliers for lines.
Offline Badger
« Reply #2 on: March 30, 2019, 06:29:46 PM »
Thanks... anyone know of a shop that rebuilds the caliper and master?
1973 CB 350 Four
Offline Scott S
« Reply #3 on: March 30, 2019, 10:25:50 PM »
 Caliper is easy. Get the seal and piston kit from DSS or 4into1.com.
 Save yourself the headache and get the replacement master cylinder for ~$45.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Bodi
« Reply #4 on: March 31, 2019, 06:06:09 AM »
For a bit over $200 you can get a (fairly accurate) repro complete caliper and MC from DSS. With new pads and lines, this gets you basically a new front brake... unless the disk is damaged, a deglaze is all it will need.
Braided lines are fairly cheap. DSS also has replacement stock rubber lines.
DSS made a big play on 400F restorations several years ago, buying every used bike they could find and turning them into "new". They found suppliers to reproduce unobtainable parts, and still have an amazing selection available. The 350 Four shares many engine and chassis parts with the 400-4.
Used brake parts are also available online or at scrappers since the 400F. 350-4, and CB350-G twin use identical components. Maybe others as well but the 350 twin was super popular and even now scrappers have bins of parts for them.
Offline Badger
« Reply #5 on: March 31, 2019, 11:05:07 AM »
Many thanks to all respondents!
Will post results when finished.  This bike was a helluva find.  33k miles but no blue smoke.  We had to trailer it home since it didn't start.  Once I dug into it, turns out I hit the jackpot.  Brand new tires, chain/sprockets, cables and new battery.  Went to replace points and found a recently installed CDI !!!
Holy Wah eh!
1973 CB 350 Four
