Nice that people design parts making it easier. These rings will make it possible to service the gauge if needed. Possible to use as a quick solution until a tool can be made crimping the real rings together. On a modified bike as Café , chopper whatever the Joker rings will fit very well.
I have NOS gauges with a very little use. since a month. Speedo needle jump around when riding.
I guess it is very happy to finally sit on a K2 it was made for after around 45 years on a shelf somewhere
I have a tool in mind using c-clamp that has 2 appr 25mm wide alu or steel piececs with correct profile squeezing the ring together. Start in one position and squeeze, then open a little and move sideways 20mm and squeeze again with a little overlap until it has gone all around.
