Author Topic: 1975 restoration/modification for a buddy- COMPLETED  (Read 4788 times)
Offline Shtonecb500
    • Youtube profile
« on: April 10, 2019, 10:23:08 PM »
I picked up this bike for my buddy, 75' stamped on the bike and 76 on the title, bike has a clean michigan title. We are going to rebuild it make him a daily rider. I just noticed the number plate on the engine is blank and didn't catch that when i first checked out the bike. I havent pulled the motor out yet, that is happening tomorrow.  Is this usually a sign of something?
« Last Edit: October 28, 2021, 01:43:04 PM by Shtonecb500 »
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Online Don R
Re: 75 750 blank number plate on motor with california sticker
« Reply #1 on: April 10, 2019, 11:42:50 PM »
Just a replacement engine case, they should have stamped it but a lot of shops didn't even own a stamp set. The engine number never matches the VIN except in a rare accident or a case like this. I own two such cases. Often a chain would break and knock a hole in the sprocket area.
« Last Edit: April 10, 2019, 11:44:24 PM by Don R »
« Reply #2 on: April 11, 2019, 01:35:15 AM »
Not unusual in the US and not a problem unless you are in a state that wants to title on engine number. As a UK resident i have never understood this as engines in anything are easily swapped its the frame/ chassis that caries the id.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #3 on: April 11, 2019, 10:54:07 AM »
Most states in the US title based on the frame number and not the engine number. I am pretty sure that in Michigan the VIN on the title should be the one on the frame neck.
Offline slikwilli420
  • Master of Disaster
« Reply #4 on: April 11, 2019, 12:22:58 PM »
Correct, frame VIN in Michigan.
Offline BenelliSEI
  • 1969 cb750
« Reply #5 on: April 11, 2019, 02:22:46 PM »
Anyone else see extra value in these motors? I have a buddy with an early K0 frame (VIN plate attached, non sand cast).  He’s been collecting parts for years. This would be useful to that project? Curious what you all think?
« Reply #6 on: April 11, 2019, 03:26:50 PM »
Although it was a common repair due to chain breakage most purists see an unstamped motor as a downgrade from the original motor, not as much as a completely different motor but still not original.
« Reply #7 on: April 11, 2019, 06:56:19 PM »
California titles had both the frame # and the engine #, and when I transferred my 750 to Arizona 20 some years ago, the AZ title also has both numbers. When I transferred the CA title on my FT500 to AZ 5 years ago, the engine # was no longer required.
Offline Shtonecb500
    • Youtube profile
« Reply #8 on: April 11, 2019, 10:30:14 PM »
does it mean it was done while the bike was still under warranty? in that case i personally wouldnt think the quality is diminished.
Offline Shtonecb500
    • Youtube profile
« Reply #9 on: April 11, 2019, 10:55:57 PM »
The motor is leaking so we are going to open it up, I'm handling this overhaul for my buddy and we have a 1k budget as of right now from his wife :)
Right now my concerns are a new main harness, motor top end rebuild, new powder coat and tires. This would pretty much eat up the 1k but get him back on the road for this season. This bike has shock lowering mounts and when I tried to return the shocks to stock position the swing arm wouldnt travel the one more inch i needed, I haven't inspected the guts of the swingers yet but i will tomorrow.
revival cycles LED signals - $90 6 units
truck lite head light - $154
harness - $80
carbkit - $40
dunlop tires tubes strips - $200
electric ignition kit dynatek in eluded coils, wires, spark plug caps, dyna s ignition - $260
versah or cometic complete rebuild kit -$100
reg rec - $60
sandblast and powder $300-350 (gonna use a new guy closer to me that does both in one place and uses a nice gloss powder coat ive seen on friends bikes)
motor rebuild - $500 plus parts so hopefully no more than $200 in parts...
geez...i grew up with my buddies wife, she is also my attorney...im gonna have to hit her up for some more cash lol.
« Last Edit: April 12, 2019, 07:39:31 PM by Shtonecb500 »
Offline Bankerdanny
« Reply #10 on: April 12, 2019, 08:44:08 AM »
Meh. If it is a sandcast then obviously the replacement case eliminates most of the premium associated with having one of those bikes. Otherwise I don't see why a no-number replacement case holding original internals with the original cylinder, head, and carbs should have any impact at all on value.
« Reply #11 on: April 12, 2019, 08:50:23 AM »
 I have several  unnumbered cases.
 One problem with them, they may not even be the right cases, there us differences. I mean they fit most years , but a 71 motor with K4 cases, ain't gonna Increase the value.
« Reply #12 on: April 12, 2019, 03:43:56 PM »
but what are the differences between 71 and 74 cases?
« Reply #13 on: April 12, 2019, 06:09:36 PM »
You really have to compare them side by side.
 I bet 71 is different in the output bearing area.
 I saw a few differences between 70 cases and others. I think one place was the area around the oil galley plug above the points, the rib underneath I think..
 I suspect they always had a fewcextras , but then the run out and use the next series.
 That said I think I would not turn down proveable KO cases with no breaks.
Offline Shtonecb500
    • Youtube profile
« Reply #14 on: April 12, 2019, 07:38:26 PM »
We got the approval for budget increase of 500-700 bucks, I purchased everything on the list plus some...we added a truck lite head lamp for $154 and LED turn signals from revival, 4 amber, 2 red for brake/running light ($90 total) for 6 units, just like my chopper set up. Dropping off the frames for powder coat on Monday and the motor is probably getting opened up the same day. Ive decided to just put a correct front end on there to have a spoked wheel set and not mix match, also going to go back to the stock 18" rear. Still need to order tires, and a battery. We we're going to get tires but he misses white walls on his rat rod so we are going to use to the tires on the rat rod for the 750 and get new whitewalls for the rat rod.
Ok ill check back later when ive got some work done.
« Last Edit: April 12, 2019, 07:40:04 PM by Shtonecb500 »
Offline Shtonecb500
    • Youtube profile
This project was delayed due to me breaking my wrist, about 10 weeks.
bike is done, I just have to wire up the rear turn signals. He wanted to have a black tank but I haven't gotten around to painting one for him, I just found the donor tank about a week ago.
I changed the rear tail lights and signals.
« Last Edit: November 11, 2019, 02:07:38 PM by Shtonecb500 »
Online Don R
« Reply #16 on: November 11, 2019, 03:05:35 PM »
 The frame has been painted a different color so it's not original anyway, on a restoration you want correct range numbers but it's a nice rider. I have a blank engine for my diecast, I think it's an upgrade in a restoration but my existing motor is newer, bored, cammed, ported and the bike has mags. Some day I may complete a restoration and use it.
 The dealers apparently didn't have a source of proper Honda font number stamps to replicate the numbers on a replacement case. You can certainly buy them for a Harley though.
« Reply #17 on: November 11, 2019, 03:42:08 PM »
Are you selling the gold tank,  let me know if you do.,
« Reply #18 on: November 11, 2019, 07:54:35 PM »
 It was hard to read but the old engine vin looked like it was stamped on the California tag that was attached to the engine. Not the top numbers but the ones on the bottom. Maybe that tag eliminated having to stamp the case.
Offline dugsgms
« Reply #19 on: November 11, 2019, 07:58:58 PM »
  Yes, especially in the early stuff. Coming from the Corvette restoration world where numbers are everything I can see where a unstamped case could be very valuable for the owner of a early 750 with a incorrect or missing engine. Especially now, as there is no database(as far as I'm aware of) that corelates frame numbers to engine numbers on the early bikes.
Here are the two sticking points as I see it. 1. can you find a stamp set with the correct font and a gang block to properly hold the individual stamps in the correct relation to each other. And 2. will there at some point in time be a database that exists that will be skewed by a improperly numbered restamp or will prove a improper restamp to be bogus.
1970 BSA Lightning
1975 Yamaha RD350
1975 Honda CB400f
2008 Yamaha WR250R
« Reply #20 on: November 12, 2019, 01:38:55 AM »
Getting the correct stamps is nigh on impossible they would have to be made, as to the numbers Honda themselves do not have records showing engine numbers and there are already out there some anomalies where owners insist the bike has never been touched.
There are case differences over the years, especially in output shaft bearing area which give away the year to the super knowlegable but not me.
Offline BPellerine
« Reply #21 on: November 12, 2019, 01:12:07 PM »
above the sprocket area on k0 cases there are only 2 case bolts,on the later cases there are 3,one dead giveaway,never seen a set of unstamped ko cases,but they may exsist.bill
1978 CB 750K ard and webers
another anfob
Online Don R
« Reply #22 on: November 12, 2019, 09:13:25 PM »
 I have two sets of unstamped cases, one has sandcast era internals I believe the other to be a 70, the bike it came from had a single cut fender. A friend swears he gave my brother a set of empty cases new in the box. My brother would have remembered that. We never figured out who got them.
Offline Shtonecb500
    • Youtube profile
« Reply #23 on: April 06, 2020, 09:04:12 AM »
Bike is all finished, here is my buddy on his first ride.
Offline adamalk3
« Reply #24 on: April 06, 2020, 09:39:10 AM »
I, too, like to take my first test rides on 94/75/275. 😬
