Author Topic: Installing Cylinder Sleeve O-Rings  (Read 488 times)
Offline Joewago
  • 1979 CB650
« on: April 12, 2019, 04:41:08 PM »
Is there some kinda trick to installing these things? 79 650. Gasket kit is from David Silver. The size is right as far as I can tell but once I push the ring in it expands and I'm left with a little dingle hanging out.
Re: Installing Cylinder Sleeve O-Rings
« Reply #1 on: April 12, 2019, 04:57:38 PM »
try lubeing em up with some dielectric/silicone grease
Offline DaveBarbier
« Reply #2 on: April 13, 2019, 04:41:03 AM »
They do look thicker than normal. They should be tight enough where they should have to be “rolled” down the sleeve and pushed into place. I remember mine expanding and getting a little dingle but I just evened it out across the entire o-ring.
Aftermarket o-rings many times aren’t correctly sized but will just about work.
Offline Joewago
  • 1979 CB650
« Reply #3 on: April 15, 2019, 05:17:53 PM »
In case anyone is reading this later, the trick is to install them evenly like Dave said. If the ring is a clock, push in 12, 3, 6, and 9, then 2, 5, 8, 11, etc. Then smooth the remaining bumps. I used a shepherds crook dental pick.
