Author Topic: And so it begins, 1977 CB750F2  (Read 1389 times)
Offline Magpie
« on: April 14, 2019, 10:00:19 AM »
Another SOHC project begins. I found this one not far from me lonely in a garage. Parked since 1984, sometimes covered up outside, mostly in a heated garage. Engine is not seized, carbs are stuck, no brakes (or fluid) of course, interior of the gas tank is nasty. I paid too much but I have never seen one around here. At closer inspection "what have I done?".
Day 1, drain the tank, put in some small sharp edged rocks to score the rust and fill with vinegar. The rest of the bike will get a thorough washing.
Offline K7-Steppy
Re: And so it begins, 1977 CB750F2
« Reply #1 on: April 14, 2019, 10:16:21 AM »
Ive done the vinegar method with great results but it's a pain in the butt. Flash rusts very quickly so you have to be fast. I let mine soak for 3 days, rinsed, added distilled water baking soda mixture, rinsed, rinsed with acetone then used red cote. I've heard good things about metal rescue but never used myself.
Sent from my Pixel 3 XL using Tapatalk
Offline Magpie
« Reply #2 on: April 14, 2019, 10:22:41 AM »
Thanks K7. My plan is top let the vinegar do it's thing, rinse, dry then use POR 15 metal prep and finish with POR 15 sealer. It works well and leaves a nice finish.
« Reply #3 on: April 14, 2019, 11:40:42 AM »
 You didn't pay too much..
 You may have bought too early ..?.maybe..
Offline jamesw
« Reply #4 on: April 14, 2019, 11:42:59 AM »
Looks like a good bike. Having the original exhaust is a plus. At quick glance, it's only missing the seat rails and correct side cover badges.
I've also done the vinegar with good results.
72K-F 750 Cafe
75K 750 Cafe
75F 750 Restoration
« Reply #5 on: April 14, 2019, 01:39:31 PM »
Pretty clean survivor.
Offline Magpie
« Reply #6 on: April 14, 2019, 02:05:07 PM »
It looks good from 10 to 20 feet away. Up close another story. It' fighting me , trying to air cleaner box off.
Offline Magpie
« Reply #7 on: April 14, 2019, 10:58:19 PM »
Nasty gas tank. I think it may need professional help.
Got the carb slides unstuck but the float pins are stuck. Ratz.
Offline kap384@telus.net
« Reply #8 on: April 30, 2019, 06:57:58 AM »
Another F2!  Take us along!
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda MR50
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
« Reply #9 on: April 30, 2019, 09:52:04 AM »
Correct sidecover badges for a 1975, 1976, AND 1977. They only changed for the 1978.
Good luck with the tank  :o
Offline Magpie
« Reply #10 on: April 30, 2019, 10:42:24 AM »
Thanks guys!
