SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Kickstart pin install
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Kickstart pin install (Read 443 times)
The Gurg
Hot Shot
on:
April 14, 2019, 10:40:51 AM »
Hey all-
Watched a video where someone hammered the pin to reinstall with a block of wood. Worried that the wood would splinter into my clean engine. Any techniques people recommend? Can I reuse the old pin with no problem? Should I maybe freeze the pin. It’s a pretty tight fit. I’m assuming I shouldn’t close the pin a little. Assuming a little assembly lube is fine? Does the top case hold the pin in or is there a possibility it can come out if it’s not wedged in tight enough?
Logged
The Gurg
Hot Shot
Re: Kickstart pin install
Reply #1 on:
April 15, 2019, 02:19:45 PM »
Wound up freezing it, putting assembly lube on it, and very carefully/gently tapping it in with a small hammer. Worked great. The upper half of the case has a piece that comes down and almost touches the top of the pin to keep it in place.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
