Author Topic: CB750 F2 How to remove air box?  (Read 2737 times)
Offline Magpie
« on: April 14, 2019, 02:16:08 PM »
Hi!
I have had some hints but I'm getting frustrated. I am trying to remove the airbox and it doesn't split like the K's. Not much room to move in there. I need to get the carbs off to rebuild them. I must be missing something? My first SOHC Super Sport. Thanks for any help offered,  Cliff.
Re: CB750 F2 How to remove air box?
« Reply #1 on: April 14, 2019, 02:25:44 PM »
Pretty sure it splits, just stuck onnthe rubber gasket I bet.
Offline Magpie
« Reply #2 on: April 14, 2019, 02:38:06 PM »
Hi Frank. From the parts book it looks like it's bolted together, there's just flat ends showing on the bottom of the box. The guy that designed this must have gone to design the GL1800 air filter system - may he burn in hell.
Offline Magpie
« Reply #3 on: April 14, 2019, 02:58:26 PM »
Thanks Frank. There's a bolt head beside the mounts. I loosened those and low and behold they hold the top and bottom together. Take out the bottom and the top is easy. You put me on the right path! Cheers, Cliff.
« Reply #4 on: April 14, 2019, 07:16:05 PM »
Cliff, be careful of the captured nut/threaded tube thingy in the bottom half...the plastic that captures them can round out and then you got a minor headache every time you need to service the air cleaner.  Yeah, why did they get rid of the thumbscrews...
Offline Magpie
« Reply #5 on: April 14, 2019, 10:54:29 PM »
Thanks. I'll be careful with it. Took a long time to figure out how to split it.  :-[
« Reply #6 on: April 16, 2019, 11:31:18 AM »
 Me too, I had one with a spun capture nut, Hondaman said a hot socket will melt in there a ways and hold the nut just in case it ever spins on you. I'd rub a little anti seize there so it doesn't ever do that.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #7 on: April 16, 2019, 02:19:33 PM »
I usually cut a slit in the bottom “captured” nut so I can use a shorty screwdriver to hold it just in case it sticks and spins in the future.  8)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #8 on: April 16, 2019, 02:29:52 PM »
I like that!  Must do.
