SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Smoking CB350F after rebuild
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Smoking CB350F after rebuild (Read 678 times)
MotoMech18
Full Member
on:
April 16, 2019, 06:12:28 AM »
Ive got a smoking CB350F that I've rebuilt. New rings, professional valve job, all new gaskets. Bike runs great but smokes which it did NOT do prior to rebuild. Plug #3 the only plug clean. Could I have damaged rings on install? If I need to pull apart again does anyone have a suggestion on a proper tool to compress the rings and make installing the jugs easier? Looking for suggestions. Thanks!
Logged
markreimer
Expert
Re: Smoking CB350F after rebuild
Reply #1 on:
April 16, 2019, 06:36:50 AM »
What pistons and rings did you use? Honda or aftermarket? Was it bored out at all? If so, what clearance did you request?
Logged
markreimer
Expert
Reply #2 on:
April 16, 2019, 06:37:17 AM »
Also did you verify all the rings were put in right side up?
Logged
MotoMech18
Full Member
Reply #3 on:
April 16, 2019, 07:28:42 AM »
I used aftermarket rings. i did not bore. I used inside micrometers on all cylinders, no cylinders out of round. I installed all top rings with the markings facing up.
Logged
markreimer
Expert
Reply #4 on:
April 16, 2019, 07:37:47 AM »
What brand of rings? There are many reports, myself included, of horrible smoking on 350F's when using Cruizin Image rings. I rebuild mine twice, and each time oil poured past the rings. That was both before and after a fresh valve job.
Logged
MotoMech18
Full Member
Reply #5 on:
April 16, 2019, 09:18:35 AM »
To be honest, not sure of the brand. Whats your recommendation for rings?
Logged
markreimer
Expert
Reply #6 on:
April 16, 2019, 01:56:05 PM »
Are you using the stock Honda pistons? If so, buy OEM rings for sure! They can be a bit tricky to find, but they're out there. I found a set in Vancouver for about $50 when I did mine a while back.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
