Author Topic: Battery keeps draining  (Read 1098 times)
Offline Monkey04
« on: April 22, 2019, 11:52:13 am »
I have installed the m-unit basic.
 Everything seems to be wired up properly, all switches and gauges are working properly. However it seems my battery keeps draining. It is a fairly new battery so it shouldn’t be a battery issue.
 Could I have missed wired something with the M unit?
Offline Jnel
Re: Battery keeps draining
« Reply #1 on: October 19, 2019, 08:16:50 pm »
The Reg/Rec... did you replace it?  In my case, i put a new one in my build and the black wire needs to go to a switched power supply,  otherwise it dtains the battery. If its connected to batery positive all the time... you get a drain.
Good luck
Sent from my SM-N950U using Tapatalk
