That's a good idea Spotty, I'll call it the redneck Redback RC51, perhaps? And thanks Per, those shocks would be good, but I think I might have enough bits to cobble together a set of half decent shocks. That's an interesting story about your Street Strokers Spotty, a friend of mine had a set of those French Fournales air shocks, the ones designed by the makers of the Concorde? They blew their seals very early in life, and as they don't have a spring, his bike looked like a Labrador dragging it's arse.
Anyhoo, I think I had a pretty good day today. I've had a nagging concern the last few weeks since I put it back together, it has been spitting fuel out of carb #1. Now that could have been a carb problem, and I did take these carbs off my bitsa bike for some reason that I really can't remember, but the most likely reason for fuel spitting out the back of just one carb, is due to an inlet valve not sealing, and the compression from the rising piston pushing the fuel/air mix back out. I found a compression gauge and shoved the rubber tip in the plug hole, and sure enough, the best I could get out of it was around 50 psi.
Hmmnn, when I cleaned up the head after replacing the two sleeves and pistons, I remember filling each of the combustion chambers with degreaser, and they both held fine, with no leaks? Maybe I over-tightened the inlet valve when I did the clearances? I wound the engine around to the "T" mark for 1/4, and sure enough, it was way too tight. I didn't bother with feeler gauges, I just backed the screw off until I could move the rocker up and down for that "Tack Tack" noise, and spun the engine again with the compression gauge in place, and I immediately got around 120 psi, so I called it good.
Swamp Rat Engine removal Monday 10 June 2019 by
Terry Prendergast, on Flickr
Ok, so time to take the engine out. Wasn't too difficult with only the footpeg bolt, the rear mounting bolt and the front right hand side bolts in place. I quickly removed the carbs, coils, drained oil tank and sump, dropped the oil filter, and jacked up the engine to separate it from the frame. I had thought about laying the frame over and pulling the frame off the engine, but Tim had gone out and I would have needed him to help manhandle it over on the trailer, so instead I got my "patient lifter" and I was happy to be able to pull the engine out without any issues. Chopping that section out for my home made "Frame Kit" really helped too, nothing for the top breather cover to snag on, easy peasy!
Swamp Rat Engine removal Monday 10 June 2019 4 by
Swamp Rat Engine removal Monday 10 June 2019 5 by
I wheeled the engine straight into my garage and due to the (very) limited space, nestled it in with my RC51 engine. Two beautiful Honda engines, both fairly unique, with 30 years difference in technology. The RC51 engine is definitely lighter than the CB750 lump!
Swamp Rat Engine removal Monday 10 June 2019 9 by
So, back to the frame. Take a look at this top triple clamp, this is what happens when people who shouldn't be allowed to have tools decide to "customise" their bikes. I assume to move the ignition key up to the top triple?
Swamp Rat Engine removal Monday 10 June 2019 9a by
I tried to seperate the fork tubes from the lower triple clamp, but in the end I just pulled the whole assembly out, what a freaking nightmare, everything was so rusty! I sure am glad that I've got a stash of parts in my garage, I think all I'll be able to use from the original swamp rat is the frame and engine, everything else (not that there was much to start with) is just too far gone..........
Swamp Rat Engine removal Monday 10 June 2019 9b by
No biggie, I finally freed up the frame from it's rusty neighbours!
Swamp Rat Engine removal Monday 10 June 2019 9c by
So next job was to start stripping the frame. I like automotive paint stripper, it beats the sh1t out of the hardware store stuff, and a few years ago I'd spent 50 bucks on this can of auto paint stripper.
Swamp Rat Engine removal Monday 10 June 2019 9d by
Sadly, the years of sitting in my garage had changed the chemical composition, and instead of coming out a brownish gel, it came out in black blobs? Bummer! I still slopped it on, and it did bubble up one or two layers of paint, but as you can see, it was a bit patchy, at best.
Swamp Rat Engine removal Monday 10 June 2019 9e by
While I'm at work tomorrow I'll work on a game plan to get it stripped back to bare metal so I can then de-rust the surface rust on some tubes, and give it a coat of paint, as the colder, wetter weather is on it's way, and if I wait too long, I'm gonna be in trouble. Wish me luck!
