Author Topic: Mix Match 750 build - next stage cheap 836 kit  (Read 69672 times)
Offline Godffery
  • Godffery's Garage
Re: Mix Match 750 build completed
« Reply #75 on: November 29, 2020, 07:38:09 PM »
The front forks are way to soft for me, It looks like the refurbished front end route isn't going to cut it.
New internal springs, heavier fluid, new brake lines, new pistons, pucks, and rubber bits.
When going threw the forks, you might want to look into installing a set of "Gold Valve Cartridge Emulators" from Race Tech.
 https://www.racetech.com/page/title/Emulators
Offline Shtonecb500
    • Youtube profile
« Reply #76 on: November 29, 2020, 09:04:18 PM »
ok, so its 200 bucks for the kit and the adapters. Every 750 ive ridden had a soft front end.
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Offline Godffery
  • Godffery's Garage
« Reply #77 on: November 30, 2020, 07:46:33 AM »
I believe there spring set is also required?
 These Preload Adjusters are a nice upgrade as well:
https://4into1.com/ttr400-preload-adjuster-set-35mm-silver-black/
« Reply #78 on: November 30, 2020, 06:32:45 PM »
I can recommend the preload adjusters from TTR400 _ great product and they work. Have them on my K2 and K4
Offline Shtonecb500
    • Youtube profile
« Reply #79 on: November 30, 2020, 06:54:05 PM »
ok, Im going to try new progressive springs, heavier fluid, and the preload adjusters first just to save some money. I might sell this in the spring so maybe going all out on the internals isn't necessary.
Offline Shtonecb500
    • Youtube profile
Re: Mix Match 750 build 70% complete
« Reply #80 on: December 01, 2020, 09:30:03 PM »
I have a set of bars just like that!
Tommaselli or something Italian I believe?  I've often seen them on old Laverdas.
as long as they dont feel funky when riding they are staying on the bike.
I found them to be pretty comfortable, not to mention super groovy!
hands down my favorite bars.
« Reply #81 on: December 01, 2020, 09:42:31 PM »
You can save some bucks by skipping the preload adjusters and making preload spacers from PVC tubing, which is what Progressive uses for their springs. Want more preload? Cut a longer set of spacers. ;)
« Reply #82 on: December 02, 2020, 08:47:51 PM »
True story!
Offline Shtonecb500
    • Youtube profile
« Reply #83 on: December 04, 2020, 08:04:18 PM »
Playing with the led lights, ordered what I needed to make some dual elements. The more I think about it the more I want to build a tail light similar to forum member gold and rustys 550 cafe.
replaced the orange light under the battery box with a red one, left the one in the front but its getting replaced because I figured its finally mounting position and I can install two up there.
pack of 10 lights for 10-12 bucks online. The only thing I noticed so far is the threads aren't that deep, so if you're taken the nut on and off they are easily to strip. Second, one of the lenses popped out but it was clean and simple, I lined it crazy glue and put it back on.
« Last Edit: January 15, 2021, 06:48:21 PM by Shtonecb500 »
Offline Shtonecb500
    • Youtube profile
Re: Mix Match 750 build done but never done
« Reply #84 on: December 09, 2020, 07:14:46 AM »
I wanted to post real fast and pay some respect to my mentor, Phil White.
I bought my first bike almost 4 years ago now and have been wrenching on them myself consistently for the last 2 plus years. While I'm in my bay working on my stuff, Phil is on the other side building restorations like the one I want to share below, mini trail side hacks, customer bikes, random resto- mods, full break down and rebuild and 836 big bore done by himself, you name it, he is doing it. While he is doing all that, he is always teaching and correcting me, giving me advice that would often take someone 3-4 times to figure out. My learning curve has been reduced greatly. I just wanted to share the restoration he is currently doing for a customer.
I feel fortunate to have learned how to build a nice Honda from him and even more so, that I am able to do it while he is retired and has the time and patience. I would have given up on building if I wasn't allowed a creative workspace to do things properly and be fed like a plant.
ENJOY.
« Last Edit: December 11, 2020, 11:01:50 PM by Shtonecb500 »
Offline Shtonecb500
    • Youtube profile
« Reply #85 on: December 10, 2020, 04:02:54 PM »
I had the time to paint the tank the color scheme I originally intended. I also wet sanded the black tank on my bike and put a fresh coat of clear on that as well. Cleared a few other things like finned plate, brake light housing, tank emblems, and random bits.
This was a side project, test my skills kinda thing. I eye balled the lines, have a total of maybe 3 hours of work time on this, painted outside while it was 30 degrees and then brought it indoors, if you zoom in you can see all the dust on the clear. I didn't wet sand in between coats. The right side was done fairly well but the left side was off considerably and bulbous. Ill have to trace with a pencil and paper over another tank with decals and lay that down on another tank. Besides not trying any kind of finishing work I think it turned out fine and will be a good riding tank. I buy these tanks for 20 bucks, use my 5 gallon of metal rescue and paint them if they turn out good on the inside. I rather have multiple tanks than trying to have 15 bikes.
« Last Edit: January 29, 2021, 11:39:03 AM by Shtonecb500 »
« Reply #86 on: December 11, 2020, 12:51:20 AM »
Your friend does top shelf work, nice early K model. Nice paintwork on your tank too!
Offline Shtonecb500
    • Youtube profile
« Reply #87 on: December 11, 2020, 04:09:40 PM »
Some sunshine
What do you guys think about the tanks? All black is just simply a VIBE.  The new tank feels like a new take on the original.....it’s not as menacing as the all black in my opinion. But hey! I can run both tanks. I decided to do away with the mini gauges, going with refurbished stock guages with chrome covers and new faces...not sure if I want all black face or all white faces.
« Last Edit: December 11, 2020, 06:52:23 PM by Shtonecb500 »
Offline Jimcg
« Reply #88 on: December 11, 2020, 11:50:12 PM »
I think you did a great job on the black and silver tank. It looks very nice! But I think the bike looks better with the black tank. The chrome and emblems are all that contrasts to the black with that tank and it just looks so cool! The silver stripes softens the whole impression in my opinion.
/Jim
1982 CB650Z RC03 owner in Eskilstuna, Sweden
About my bike:
http://forums.sohc4.net/index.php/topic,183848.0.html
Just the pictures and no text:
https://www.flickr.com/photos/189154615@N04/?
Offline Shtonecb500
    • Youtube profile
« Reply #89 on: December 12, 2020, 09:38:55 AM »
/Jim
Softens is a great way to put it, I agree. Im still working on the rear taillight, not the route I wanted to go with it but its practicality has won me over..thats why I had to paint it. The new issue is the way  is sits because it slants with the fender and I need it to sit in line with the frame rails/lines of the bike. Ive decided to take the l brackets I made for the signals and just weld them right onto the fender just tucked under the seat where its welded already. The turn signals are going to become red running and or brake lights and the stock fender holes will receive two more motogadget pins.
« Last Edit: December 12, 2020, 09:59:49 AM by Shtonecb500 »
Offline Shtonecb500
    • Youtube profile
« Reply #90 on: December 14, 2020, 04:13:04 PM »
Gauges are on, I went the cheapest route and used what I had, rather put 40 bucks for new black face plates towards fork upgrades at he moment. I wasnt sure which color to use since I was breaking with the overall black, grey, metal scheme. I had a set of nice blue (which i used) and a set of green faces. Ill probably swap in the green faces just to see if I like them, probably buy the white and or black ones as well anyway. They are much larger than the mini units I had up there and change the feel of things. But they are large, nice, work, and look clean. Plus, that fairing is going back on so you cant see whats back here anyway.
« Last Edit: December 18, 2020, 01:50:46 AM by Shtonecb500 »
Offline Shtonecb500
    • Youtube profile
« Reply #91 on: December 19, 2020, 12:23:18 PM »
would these work? https://www.ebay.com/itm/Honda-CB750-SOHC-69-78-Air-Fork-Caps-Cafe-Chopper-Bobber-AHRMA-Rat/324370227232?hash=item4b85f8e020:g:2BUAAOSw7b9frCyp
Offline Godffery
  • Godffery's Garage
« Reply #92 on: December 19, 2020, 12:39:16 PM »
 The issue with pressurizing the forks, is blowing the seals.
Offline Shtonecb500
    • Youtube profile
« Reply #93 on: December 19, 2020, 01:01:25 PM »
Offline Shtonecb500
    • Youtube profile
Re: Mix Match 750 build completed until luggage racks
« Reply #94 on: December 22, 2020, 07:49:09 PM »
Im pretty excited to have a few dream bikes for myself to ride this summer.
« Last Edit: February 07, 2021, 08:39:06 AM by Shtonecb500 »
« Reply #95 on: January 29, 2021, 03:51:02 AM »
Beautiful build!  What fairing do you have on it at the BOM thread?
Online Kevin D
  • SE Michigan
« Reply #96 on: January 29, 2021, 04:51:37 AM »
ENJOY.
Is this the same Phil “The Doctor of Honda’s” ?
71 CB750 K1
108,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
Offline Shtonecb500
    • Youtube profile
« Reply #97 on: January 29, 2021, 11:28:15 AM »
Thank you, It's an old Shoei I scored off another bike that was restored.
Offline Shtonecb500
    • Youtube profile
« Reply #98 on: January 29, 2021, 11:29:08 AM »
ENJOY.
Yes it is, I managed to meet him when he retired and I've been working out of his shop since. Its been incredibly fun.
Offline grcamna2
« Reply #99 on: January 29, 2021, 12:37:23 PM »
Very Nice work you're doing.That swing-arm was excellent to get on that bike you bought:what a bonus.  8)
75' CB400F/'bunch o' parts'
