Author Topic: are these cb750k sohc exhaust pipes (solved)  (Read 1038 times)
Offline setdog
« on: May 02, 2019, 07:10:18 PM »
hello, need a bit of expertise to help me sort this out.
i have a 78 cb750k cylinder head, and i came into possession of these exhaust pipes.
they seem to fit into the ports ok(?), but the exhaust flanges and the collar (or whats left of the collar)
that came along with them do not seem to fit at all.
based on what i can tell, these flanges (and the collar) might be for a 79 DOHC CB750.
which leaves the question of whether i can still take advantage of these pipes in a 78 cb750 k8 head,
if i use correct flanges and collars.
this build is a low budget jalopy resurrection that started with a bare 73 frame. the goal is to simple get it operational, so while these pipes might be hard for some of you to look at, i hoped i could just wrap them up and enjoy some old 4 into 2 slash cut pipes. Even if my neighbors won't.   ;D
« Last Edit: May 04, 2019, 05:43:30 PM by setdog »
My toolbox consists mainly of hammers.
76 CB 200T. (sold)
75 CB 750 K5. (sold)
74 CB 750 K4. (current rider)
73 CB 750 K3. (build)
https://www.youtube.com/user/setdog100
Online BenelliSEI
  • 1969 cb750
Re: are these cb750k sohc exhaust pipes?
« Reply #1 on: May 02, 2019, 08:44:40 PM »
I have a ‘78 and agree the finned, chrome collars don’t look quite right, but if they fit over the flared end of the pipe, and slide down on the studs, why wouldn’t they work? They rarely get bolted right down to the stud base on the head. If you use a new copper gasket (the one like a big O ring) under the pipe, then side in two of the 1/2 collars, do they Seat well in the chrome collars? You’ll need 8 of the 1/2 collars.......
The pictures aren’t too clear, so I may be misssing something?
« Reply #2 on: May 02, 2019, 09:08:05 PM »
 Be sure the inserts are turned the right way.
Offline Dolomite
  • I'm 40% Dolomite.
« Reply #3 on: May 03, 2019, 06:55:31 AM »
My 78K has those style exhaust clamps, they only fit one way so try rotating 180* if they don't line up correctly. With the 1/2 collar and copper gasket underneath.
Online BenelliSEI
  • 1969 cb750
« Reply #4 on: May 03, 2019, 08:53:18 AM »
The other reason the fins are stepped on the chrome collars is to clear the frame down tubes on #1 and #4........
Offline setdog
« Reply #5 on: May 03, 2019, 02:52:36 PM »
here are some additional pics
hopefully one shows more clearly the gap between the flange and the exhaust port,
the other hopefully shows the gap between the pipe and the flange.
i dont see how these could possibly be from a 78 cb750K as stated.
additionally the pipes seem to be a smaller diameter, but the end of the pipe does fit squarely into the
opening where the copper gaskets seat.  oh and now im worried about them fitting past the kick stand and
being able to actuate the gear lever without interference
ill see if i cant get some 78 k parts to fiddle with over the wknd
« Last Edit: May 03, 2019, 02:54:50 PM by setdog »
76 CB 200T. (sold)
Offline Bankerdanny
  • Endeavor to persevere
« Reply #6 on: May 03, 2019, 03:02:20 PM »
Where are the rest of the 2 piece sleeves that fit inside the finned collar? I see one in your photo, there should be 8, 2 per pipe.
Those fit snuggly over the pipe, long side towards the head. Then the finned collar slides over that and onto the studs. The finned collar won't go all the way to the head when it is tightened.
« Last Edit: May 03, 2019, 03:04:48 PM by Bankerdanny »
Offline setdog
« Reply #7 on: May 03, 2019, 03:11:59 PM »
i only have 1 of 8.  and it appears to match exactly oem part number 18233-438-000, which i believe is 79-82 dohc.
even tho i only have the one, the gap seems too big you can see it in one of these pics
ugh...i feel like ive been bamboozled
you can also see how well the end of pipe fits into the port
mind you, i never expected oem, but if they "came off a 78 cb750k" i would expect to be feeling more confident at this stage
« Last Edit: May 03, 2019, 03:23:25 PM by setdog »
76 CB 200T. (sold)
Offline Bankerdanny
« Reply #8 on: May 03, 2019, 03:39:38 PM »
The gap is big because there is supposed to be a 2nd half of the sleeve.
« Reply #9 on: May 03, 2019, 04:38:47 PM »
The finned clamp goes on the pipe first then fit the pipe into the head port, with a gasket, two half round clamps, with the lip towards the clamp,  then hold the pipe in when finned clamp is done up. Picture in parts book shows it all
Offline onepieceatatime
« Reply #10 on: May 04, 2019, 03:58:02 AM »
Those are definitely DOHC style finned flanges. The fins on one side being so much larger is the give away. The '77 and '78 SOHC CB750K and I think the '76 CB750F flanges were the same type, with the split collars, but the fins were more even.
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Online BenelliSEI
  • 1969 cb750
« Reply #11 on: May 04, 2019, 04:37:01 PM »
Agreed...... ‘77 and ‘78 chrome fins are stepped, but only slightly.
Offline setdog
« Reply #12 on: May 04, 2019, 05:43:15 PM »
pretty sure i figured out my situation and have a solution.
the  flanges (with the long fins) i got are most certainly DOHC.
the pipes are idk what they are.
picture tells all.
the second pic is my solution, an RC Engineering 4 into 1.
i dont have to pull the exhaust studs on the head do I?  any reason i cant
just use nuts to secure them?  there is alot of rust, a small hole near the collector and
about a walnut sized hole under the megaphone, but i think i can easily
deal with those.
« Last Edit: May 04, 2019, 05:48:47 PM by setdog »
76 CB 200T. (sold)
Re: are these cb750k sohc exhaust pipes (solved)
« Reply #13 on: May 05, 2019, 12:50:25 AM »
Yeah just nuts, try acorn nuts if you can get them..May need spacers.
