Author Topic: Piston install pics....  (Read 3822 times)
« on: January 26, 2007, 10:18:14 AM »
This is for Andy750's bike. The cylinder went on in 5 minutes....I'm sure they put 4 or 5 on in that at the factory. ;D
Re: Piston install pics....
« Reply #1 on: January 26, 2007, 10:21:43 AM »
Wooohooo!! Nice surprise! Looking good Mike!!  ;D I love the pics - crystal clear, just like the head....nice job. The Chimay is on me this time for sure!
For those who dont know...Mike is redoing the top end of my CB750K4 - stock bike (more or less) thats been 40,000 miles in the last 5 years (crossed America a couple of times, been around Europe and the Alps and even made it to Scotland and back). Some may recall I tried doing the head myself last year and almost succeeded (except for a few mistakes here and there  ::))......anyway I am super happy with Mikes work and hes done a great job so far (I saw the engine at the half-way stage) -just amazing. If anyone is even considering asking Mike to do some work I can highly recommend him! Second to none in my opinion. Thanks Mike!
cheers
Andy
« Last Edit: January 26, 2007, 10:26:44 AM by andy750 »
Offline scondon
  • Mmmm......tasty bugs
« Reply #2 on: January 26, 2007, 11:58:39 AM »
 Dig the blocks to keep the pistons from rocking while installing the cylinder :)  Is that Gaskacinch or some other tacky gasket stuff around the base gasket oil drains? I'm takin' notes ;)
  Super clean Mike. Just like your headwork.
« Reply #3 on: January 26, 2007, 12:34:13 PM »
Thanks Sean. Those adjustable blocjs are Suzuki pieces though others make them. You get the upper case surface pretty level, put those under the pistons and turn the crank until the pistons are pretty much centered in the bore. The cylinder slips over the pistons so easily once the pistons are stablized it's hard to believe. I just work the cylinder down to 1&4 and basically rock them in their bores. The sealent is a real thin layer of Hylomar. And yes...I know the cam chain blade is missing. I found a new one on ebay for 15.00, it arrived today and it is in place.
« Reply #4 on: January 26, 2007, 09:32:21 PM »
OK, I'm jealous now. Where are my pix?!  ;D
« Reply #5 on: January 27, 2007, 08:40:14 AM »
I knocked the valve guides out last night Jerry. The parts should be in early next week and then it's off the machinists for the combustion chamber mod, valve job etc. I'll post some pics when it's done. ;)
« Reply #6 on: January 27, 2007, 08:53:52 AM »
hey Jerry wait in line! No pushing at the back there  ;)
Hope all is well in CO!
cheers
Andy
Offline Pinhead
  • 1979 CB652-ST
« Reply #7 on: January 27, 2007, 10:15:02 AM »
You've got me very interested. What combustion chamber mod? Are you hemi-ing the chamber or something else?
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline Master Ted
« Reply #8 on: January 27, 2007, 10:28:01 AM »
Andy, what exactly are you having done to this motor?
CB750/K2
Offline Hockers Choppers
  • go away winter!!!
« Reply #9 on: January 27, 2007, 11:30:30 AM »
nice idea with the blocks!
The thing about common sense is that, it's not that common.
1978 CB750F SUPERSPORT 850cc, cam, porting, dyna ign, cr29's lotsa elbow grease and $$'s. Worth ever penny!!  (S0ld)
05 VTX1800F darkside
cb750 k1
« Reply #10 on: January 27, 2007, 12:46:34 PM »
Staphcar,
Nothing too serious....cylinders honed (better than the first time they got done), new pistons, rings, cometic headgasket, new valves, guides and Mike has generously done some mild porting for me as well so Im excited! When Mike opended up the engine the pistons were scored (oil on sides), valve guides wasted, some valves were worn etc etc....so generally an all round clean up and with Mikes excellent attention to detail I have complete confidence its going to be good!
cheers
Andy
« Reply #11 on: January 27, 2007, 06:53:57 PM »
Staphcar,
cheers
Andy
I replaced Andy's head with one I had. His was in rough shape and the pistons shot. They had those 1 piece oil rings. ::) Actually most of the parts were low mileage( rings and seals are new) used but it got a fresh valve job and surfacing. It should run pretty good.
« Reply #12 on: January 27, 2007, 06:56:15 PM »
Jerry's head will be going on a 1080CC kit. The chambers have to be opened up using a squish cutter to accomodate the large pistons.. It does produce a more hemi chamber.
« Reply #13 on: January 27, 2007, 06:57:09 PM »
Thanks. They can be easily made too.
Offline Pinhead
  • 1979 CB652-ST
« Reply #14 on: January 27, 2007, 06:59:05 PM »
Cool! Be sure to get a LOT of pics of that. I want to see the chamber!!
Doug
:D
« Reply #15 on: January 27, 2007, 07:09:31 PM »
Here is one with the chambers opened a bit.
Offline Pinhead
  • 1979 CB652-ST
« Reply #16 on: January 27, 2007, 07:39:28 PM »
No squish?
Doug
:D
  • go away winter!!!
« Reply #17 on: January 28, 2007, 07:21:42 AM »
Yes, I took a piece of 1x pine and cut out a "fork" that runs under the piston.
cb750 k1
  • go away winter!!!
« Reply #18 on: January 28, 2007, 07:28:10 AM »
what does that chamber measure across? I have one in my pile that measures 70mm, it's chambers are smooth like that one also, and it has been ported big time! Anyone need it?
cb750 k1
« Reply #19 on: January 28, 2007, 07:50:43 AM »
No squish?
Tapered/blended squish. http://www.muller.net/mullermachine/docs/squish1.html There are other, and better writ ups. There was a very good one from a performance place in Australia I read a while back. i wish I could remember it.
« Last Edit: January 28, 2007, 07:55:36 AM by MRieck »
« Reply #20 on: January 28, 2007, 07:57:24 AM »
If I remember correctly they are about 66 mm across Jesse. That 70 must have been for a 1080.
Offline scondon
« Reply #21 on: January 29, 2007, 10:24:17 AM »
     My open tube of Yamabond4 is just over a year old so I'm going to buy some more sealant to button up my motor. The write up on Hylomar looks pretty good so I'll give it a shot. Looking online I find a "universal blue" and a "racing blue" formula, along with a bunch of other Hylomar products. Which formula do ya recommend, Mike?
