Author Topic: CB550 carbs  (Read 565 times)
Offline Peekster
  • you are probably underestimating me
CB550 carbs
« on: May 04, 2019, 04:52:49 PM »
SEND HELP
i am assembling my carbs and i need all the references tips and diagrams i can get.
1974 CB550
Modifying custom parts
Offline Peekster
Re: CB550 carbs
« Reply #1 on: May 05, 2019, 04:57:42 PM »
Ok it must have been something I said. I have completed torn apart my carbs and cleaned them to perfection. I got them all together and was wondering a good base tune. Also how do I set my floats to stop the leaking?
1974 CB550
Offline Deltarider
Re: CB550 carbs
« Reply #2 on: May 06, 2019, 12:27:23 AM »
In order to help you, please specify what model CB550* you have: CB550K, CB550K1, CB550K2, CB550K3, CB550K4, CB550F, CB550F1 or CB550F2. Also inform us what carb number you find on yours.
* To identify, compare the engine- and framenumber to those listed in the first few pages of all CB550 Parts Lists. They are all here: http://www.honda4fun.com/materiale-documentazione-tecnica/parts-list/parts-list-cb550
CB500K2-ED Excel black
Offline Bankerdanny
  • Endeavor to persevere
Re: CB550 carbs
« Reply #3 on: May 06, 2019, 08:58:44 AM »
Also, the factory repair manuals are found via the Manuals Link at the top of the forum home page.
If you have a 550F or 74-76 550K with original carbs then check the choke butterflies to make sure they open and close in synch. Then you need to bench synch the slides so that they are all approximately the same height to start with. For the carbs on the bikes I listed (which will have 022A or 069A stamped on the #4 carb or the manifold near the #4 carb) use a small drill bit (I usually use 1/8" some like 1/16) and set the carb slides so that the bit slides in from the airbox side with minimal resistance. You will fine tune the slide synch later when the bike is running. If you have a 77-78 550K then it has PD type carbs (the top looks kind of like an old fashioned skeleton keyhole), the #2 slide height is fixed so use it as a reference point to set the height of the others.
The floats are leaking from where? The tube at the bottom of the bowl? That generally means you need to adjust the float since that is it's purpose. As the bowl fills with fuel the float rises pressing on a needle the blocks off the input hole the feed fuel to the carb. I like to clamp my carb rack to a vertical source so hook up an auxiliary fuel tank to test for leaks before I mount the carbs back on the bike.
Offline Deltarider
Re: CB550 carbs
« Reply #4 on: May 07, 2019, 06:39:51 AM »
I disagree. Although a possibility (maybe the PO has messed with them), I myself never had to (re)adjust a float. What I have seen however several times is floatneedles not closing the valve completely due to debris. It takes a tiny particle of dirt...
Offline CB400JAY
Re: CB550 carbs
« Reply #5 on: May 07, 2019, 10:20:30 AM »
I worked as a professional Honda mechanic in the 1970's and have worked on easily over a hundred machines.  I have had to adjust float levels dozens of times.  Change the needle and seat or the float, adjust the float level.  Under the circumstances this is something that I would recommend checking.
Offline Bankerdanny
Re: CB550 carbs
« Reply #6 on: May 07, 2019, 11:41:09 AM »
Do you know if the float seats and needles are the original Keihin units? If they are reproduction parts the needles are sometimes shorter than stock and so the stock float height settings don't work properly. If I decide that the float needles need replacing I always by OEM Honda or Keihin branded parts.
Offline Deltarider
Re: CB550 carbs
« Reply #7 on: May 07, 2019, 12:28:40 PM »
There you have it in a nutshell: buy cheap aftermarket junk and you can bet you have to adjust...
