Hi again
I been trying to wire up my bike, as i mentioned in an earlier thread, i have a new loom and most of it was easy, but for 2 days now i been stuck in the headlight bucket trying to do the warning/indicator lights.
The turn signal, the turnsignallamps themselves work fine, if i try hook the light blue from the indicator/warning lamp to the light blue on the loom and orange to orange, the indicator lamp only works with the right side turnsignal, i also seem to get some ground issues when i do that, seems the left turn signal bulb glows slightly.
Then the oil pressure waning light, this has a blue with redstripe if memory serves me right, and a black wire, which i think is a black wire shared with the neutral lamp? i cant tell for sure since it so thight between the wires and heatshrinktubing its very hard to acsess properly. However the neutral lamp works fine. No matter what i do, i cant get the oilwarning lamp to light up.
However i used a multimeter and "beeped" the wire going thru the loom down to the pressure switch and put the other end on ground to see if i had a connection, and nothing. I beeped both ends of the wire just to see, and the wire is fine. Shouldnt the pressure switch be grounded? if it should, can this be a result of a faulty switch? i cant remember now but im starting to wonder if i put some thread sealant tape on the threads for the pressure switch, could that be the issue? i dont know if thats enough to not give it ground. Any other suggestions?
Also when i hooked up the flasher relay, there was 3 remaining wires, one green, flat female, one grey flat female, and one black flat female, the flasher relay only had two connectors, grey and black. So where does the flat green female go? most logical to me would be if i had another green wire with a flat male, and ring in the other end, and it goes to battery negative? i cant see it on the wirering diagram.
There was also a round/ring connector green in that area which i grounded to frame, is that correct or have i somehow messed up the green wires and its that one going to the battery?
Sorry for a lot of questions, but at this point im a bit frustrated and confused.
Thanks in advance for you help.
