Author Topic: Corrosion on Bolts and Nuts  (Read 1125 times)
Offline The Gurg
« on: May 06, 2019, 06:15:36 PM »
Just seeing if the corrosion pictured is an issue?
Offline jtb
  • An unlikely
Re: Corrosion on Bolts and Nuts
« Reply #1 on: May 06, 2019, 06:45:14 PM »
Probably not
1977 CB750F
1985 V65 Sabre
« Reply #2 on: May 06, 2019, 07:00:18 PM »
pretty easy to clean them up before use...just douse a piece of 0000 steel wool in wd40 polish it up real quick and wipe the excess with a clean rag.  You will be surprised how much oem hardware is still in useable shape
Offline The Gurg
« Reply #3 on: May 06, 2019, 07:05:57 PM »
Yeah I wouldn’t stick them in that way. Appreciate suggestions on what to do.
Not sure if I have any steel wool lying around. Have some copper scouring pads or a steel wire bench wheel. I can make a trip if the steel wool would be a lot better.
« Reply #4 on: May 06, 2019, 07:11:26 PM »
copper scouring pads work in a pinch.  The steel wire wheel will result in very clean and shiny bare steel, but it won't last, as you have just totally removed whatever was left of the plating.
Offline The Gurg
« Reply #5 on: May 06, 2019, 07:28:41 PM »
Ok awesome, I’ll run out and pick some up. Appreciate the help guys!
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
« Reply #6 on: May 06, 2019, 11:25:18 PM »
+1 on not using wire wheel
I did this and now the heads of all bolts are an unsightly brown colour :(
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
Offline BPellerine
« Reply #7 on: May 07, 2019, 05:34:44 PM »
if they were rusty they will rust again no matter what method you use,clearcoat did not work for me on some items I tried.bill
1978 CB 750K ard and webers
another anfob
Offline Kelly E
  • Geriatric Hooligan
« Reply #8 on: May 07, 2019, 08:12:34 PM »
Use EvapoRust, they will be as shiny as they can be with whatever plating was left still intact. Throw them in today and install them tomorrow. 8)
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
Offline The Gurg
« Reply #9 on: May 07, 2019, 09:03:18 PM »
We have a specialty hardware place in town that has a large warehouse. Would it be ok to get engine hardware from them, zinc plated stainless steel, right? Or am I better off with evaporust or steel wool and wd-40. For what it’s worth I now have the steel wool and wd-40 on hand.
Getting old Honda parts takes forever, is sometimes discontinued, and is expensive.
Offline jgger
« Reply #10 on: May 07, 2019, 09:16:28 PM »
Why would you zinc plate a stainless steel bolt?
The only concern for aftermarket bolts would be the grade of the new vs. the old, sometimes that is real important.
Offline The Gurg
« Reply #11 on: May 07, 2019, 09:34:22 PM »
Oh I misspoke I meant zinc plated steel bolts. That’s what Honda used on engine internal bolts right?
Offline disco
« Reply #12 on: May 07, 2019, 10:39:54 PM »
Mine were like that too. I used a wire wheel to buff them. Then hit 'em with a zinc rich etch primer. Should be good for another 50 years! In any case I won't be around to worry about it! 😂
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
