Author Topic: Tail Light Bracket Ideas  (Read 580 times)
Offline DHuffman
  • '77 CB750F
    • Follow me on instagram!
« on: May 07, 2019, 07:55:23 AM »
Hey guys,
I'm trying to decide how to mount the tail light on my build and am wondering what some of you guys have done. I added a frame hoop for a brat style seat. I'd like to add a tail light similar to this (http://airtech-streamlining.com/images/HLR12~1.jpg). Ideally, I'd like a bracket to attach under the frame hoop, but don't want it to be a style that wraps around the frame tubing.
Any suggestions?
Re: Tail Light Bracket Ideas
« Reply #1 on: May 07, 2019, 08:06:16 AM »
Yeah, weld a threaded tab under the hoop to inside.
 Or drill into hoop, then weld threaded sleeves In. If they have a flange, easier to weld.
Offline DHuffman
  • '77 CB750F
« Reply #2 on: May 07, 2019, 08:11:48 AM »
 I was hoping there was some kind of bracket made for the hoops since I do not actually have a welder. I'll probably end up hauling it to my friend's place and use his welder and add a tab as you suggested.
« Reply #3 on: May 07, 2019, 10:09:40 AM »
Drill and tap the hoop.
Offline SF
  • I burn gas very well
« Reply #4 on: May 07, 2019, 02:29:09 PM »
There are rivnuts
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
« Reply #5 on: May 07, 2019, 08:55:39 PM »
 The strongest you can be is to weld something on. .
 Don't let poor planning get in the way of well built.
 Is it painted already.
The problem with rivnuts or tapping they are all sort of in one line, a triangle or square mounting system is better once that weight starts bouncing around..
Offline DHuffman
  • '77 CB750F
« Reply #6 on: May 08, 2019, 12:30:39 PM »
It is painted, but it was just a rattle can job on the frame hoop i added, so I'm okay with touching it up. I'm not building a show bike.
