SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
The
SOHC/4 World Tour
is in under way.
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
How much vapor is normal from the breather?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: How much vapor is normal from the breather? (Read 576 times)
jorwesflow
Hot Shot
we're not schizophrenic
on:
May 09, 2019, 08:40:50 PM »
I know that in stock, the hose goes into the airbox, and you can't really see the vapor. But I've had pods and this breather filter for years now, and have always wondered what amount of vapor is normal. It seems it increases along with the temperature.
//www.youtube.com/watch?v=cZf6HIRNzEI
Logged
1977 CB550K
Don R
My Sandcast is a
Really Old Timer ...
Saver of unloved motorcycles.
Re: How much vapor is normal from the breather?
Reply #1 on:
May 09, 2019, 10:37:12 PM »
It totally depends on engine wear, state of tune, outside air temp, how hot it gets during a ride. Looks about what I'd expect. On race cars they put a sock over it to catch the oil. Then, change it occasionally.
Logged
PeWe
Bike almost back to the 70's 2015
Reply #2 on:
May 10, 2019, 03:07:04 AM »
You don not feel the smell when standing still with engine running?
A longer hose will not let the fumes to hit the face if routed backwards behind the foot pegs. I have that on my CB750's. My K6 had a long hose all the way to passenger foot peg. My K6 has a n extra breather hose from clutch cover, short hose routed up between carb 2-3 pods.
Logged
CB750 K6-76 970cc (Earlier 1005cc JMR Billet block on the shelf waiting for a comeback)
CB750 K2 -1975 build thread
disco
Hot Shot
Reply #3 on:
May 10, 2019, 03:32:41 AM »
Lots of short distance riding will also increase the amount of vapour.
It regularly needs a good long ride to get the oil up to temperature to remove water vapour.
Logged
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
Bodi
Reply #4 on:
May 10, 2019, 08:09:47 AM »
This is likely just piston blowby - not terribly bad but a tight engine would have less. Or badly worn exhaust guides, not so good.
Engine hot or cold? I would be concerned if cold.
On a cold engine water vapor in the blowby will condense into the oil but that is not any problem. The amount is trivial and it will boil off when the engine gets to normal running temp.
If that "steam" is condensed water in the oil boiling off... totally normal and no cause for concern. But I don't think it is.
Logged
PeWe
Reply #5 on:
May 10, 2019, 08:53:31 AM »
It will look like more vapor when ambient temp is lower.
Agree on the importance of long rides boiling the water out of the engine. Oil temp of 100C + needed.
Logged
Bodi
Reply #6 on:
May 10, 2019, 10:16:42 AM »
The other question is - how quickly does that filter get saturated with oil? If it's dripping oil after a couple hours riding I think you have a piston ring sealing problem. I have a similar filter on the 400F and it needs a solvent bath only after hundreds of miles. I do get smoky (and smelly) blowby coming from it when the engine is idling and really hot, nothing noticeable when cold.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
