Author Topic: '78 550k - front brake binds when turning left  (Read 665 times)
Offline toomanybikes
« on: May 22, 2019, 04:23:02 PM »
When rolling the bike around the garage/driveway, if I have the handlebars turned to the left, the front brake will engage. Does anyone know why this might happen?
The caliper has a new piston and seal, fresh fluid, etc. I did not replace the hose or master cylinder, but I wouldn't think that's the problem since it only happens when turing left, right is fine.
Thanks
current stable, always subject to change ...
'80 CB650C
'82 GL500
'81 Suzi GS450L (cafe)
'03 Suzi SV650
'07 Yamaha VStar 1100
'10 Bonnie
'14 VFR800
Offline Bankerdanny
  • Endeavor to persevere
Re: '78 550k - front brake binds when turning left
« Reply #1 on: May 22, 2019, 04:40:11 PM »
Check to make sure the axle is firmly secured to the bottom of the fork. The only reason turning the bars would cause brake binding is because it makes wheel get out of parallel with the forks. Also make sure the lower brake hose is properly secured in the bracket.
Offline RustyF
« Reply #2 on: May 23, 2019, 04:15:17 PM »
If you check all your fixed point bolts for the caliper, axel and fork cap nuts, I then would look at the wheel bearings to see if you have one on the way out and allowing the wheel to cock causing the brake to bind.  Let us know when you find the issue.
1978 CB 550 K
« Reply #3 on: May 24, 2019, 03:31:44 AM »
Thanks all. I loosened all the fork, steering tube, axle, and brake bolts and then rolled it around for a while. This loosened things up, although still not perfectly free.
Then I noticed the front wheel was off center because the axle was installed wrong. Doh! My bad. I assume that will free it up the rest of the way and will correct it tomorrow.
'80 CB650C
'82 GL500
'03 Suzi SV650
'10 Bonnie
'14 VFR800
« Reply #4 on: May 24, 2019, 03:44:02 AM »
« Reply #5 on: May 24, 2019, 04:34:25 AM »
Yup, a good bonehead move every once in a while helps keep us DIY mechanics on our toes.
'80 CB650C
'82 GL500
'03 Suzi SV650
'10 Bonnie
'14 VFR800
