Author Topic: 80’ cb650c BARELY charging  (Read 1906 times)
Offline Easyskankin
« on: May 24, 2019, 08:58:42 AM »
My 1980 cb650 is barely charging. New rotor just installed. Reg/rec works battery fine. I’ve checked resistance in the key switch and fuse channels all normal. Wiring is solid. V drop tests are normal. Hoping someone can point me in another direction. Thanks, respect.
Offline Easyskankin
Re: 80’ cb650c BARELY charging
« Reply #1 on: May 24, 2019, 10:19:01 AM »
Right, I checked resistance in the reg and it checks out fine also it’s not overcharging. I can’t get it over 12.5 V and that is at 5k rpm and above. The battery holds charge at over 12V. Maybe they’re aren’t fine what are you thinking?
Offline Easyskankin
« Reply #2 on: May 24, 2019, 04:03:01 PM »
Charging now. Thank you for the time. Will report tomorrow
