Author Topic: Need help with push throttle cable  (Read 1433 times)
Offline telupo
« on: May 31, 2019, 02:13:17 PM »
For whatever reason I can’t seem to get my push cable far enough to catch on the latch? hook? Am I missing something? Is there a trick to this? The pull cable on the top fits perfectly well but the on on the bottom seems to short by about 5 mm when I pull it, and I’m sure it’s the right cable.
Re: Need help with push throttle cable
« Reply #1 on: May 31, 2019, 03:11:31 PM »
What brand cables are those?  Something does look wrong...
Offline telupo
« Reply #2 on: June 01, 2019, 06:55:06 PM »
I bought two different cables 1 from 4into1.com and a second I had ordered from I local shop called motion pro. Both are the same length but for whatever reason there doesn’t seem to be enough wire to go around the bottom.
Offline BenelliSEI
  • 1969 cb750
« Reply #3 on: June 05, 2019, 04:57:03 AM »
You’re not doing anything wrong. If the inner cable  is too short to reach, it’s the wrong cable. Do you still have your old one? How do they compare?
Offline telupo
« Reply #4 on: June 07, 2019, 07:11:23 PM »
Unfortunately the old one kind of unraveled to I couldn’t really tell the length.
