Author Topic: I am a dumbass...but only temporarily  (Read 5090 times)
Offline Bankerdanny
  • Endeavor to persevere
Re: I am a dumbass
« Reply #25 on: June 10, 2019, 12:14:56 PM »
:o :( :( :'( Hopefully repair won't cost too much.
It's going to cost about $200, $100 for the debt removal stud gun I bought and about $100 for paint,  clear coat, and supplies.
  Is that "debt removal" a Freudian slip Dan --  ;D
LOL, definitely
Offline Bankerdanny
Re: I am a dumbass
« Reply #26 on: June 10, 2019, 12:25:01 PM »
OK, dents out and a coat of etching primer laid down before I went home last night.
You can see the outline of the filler underneath, but when you run your hand over it everything is smooth.
Offline JeffK
Re: I am a dumbass...but only temporarily
« Reply #27 on: June 11, 2019, 07:11:42 PM »
I'm sorry that happened to you Danny. I will admit I do find a little relief knowing I'm not the only person that could happen to.
Jeff
Offline Bankerdanny
« Reply #28 on: June 12, 2019, 12:34:12 PM »
I am going to try and get the primer all done today and tomorrow along with a base coat then add the color and clear next week. hopefully all will be done before I am supposed to leave on my 2 week trip on the 23rd. I also need to track down an electrical short that is blowing the main fuse and replace the old front master cylinder I installed as a stop gap. I will be riding through mountains with a fully loaded bike and want fully functional brakes.
« Reply #29 on: June 13, 2019, 07:18:24 AM »
 That's what we do Danny, Take a deep breath and dive back into it. Looking good so far. I have a similar tank, the dent is smaller and a drip of brake fluid ate the spray bomb paint. Same result.
   I allowed a parts store guy to sell me some cans of spray bomb cra (p) that lifted and caused all sorts of trouble.
Offline Bankerdanny
« Reply #30 on: June 13, 2019, 07:52:21 AM »
Thanks Don. I need to figure out why the filler under the primer always seems to be visible. Even with the prior paint job there was one spot where I used filler on a shallow dent that was definitely visible when you looked closely. It will have filler in more spots this time and I really don't want it to be visible.
Online RAFster122s
« Reply #31 on: June 13, 2019, 09:05:48 AM »
Seems like filler sucks in the paint as it finally cures. Not sure if a primer sealer for the first couple coats would stop this or not. Imagine epoxy primer would.  Guess we will have to pick the brain of a good paint guy to find out the cause. It seems to take a while for it to show up on good paint jobs.
Repaintsupply.com has good prices on Spraymax urethane in a good spraybomb.worth the money for it to laugh off gas spills and probably brake fluid as well.
You have to use proper respirator and cover your skin when spraying urethane, it can be pretty lethal if not respected.
David
Offline nvr2old
« Reply #32 on: June 13, 2019, 09:08:07 AM »
Etching primer is designed to simply cover bare metal and to keep a part from flash-rusting.  May I suggest (as mentioned above) using a polyurethane high-build primer at this stage.  It'll fill in all your sand scratches and low spots, and after block sanding, give you a really good finish to apply your base coat to.  You can get it in a spray can for about 10 bux per can.
'76 CB550F-'72 XL250-'82 MB5-'82 CX500 Turbo-'77 naked Goldwing-'75 CB400F cafe'-'79 Suzuki GS1000S..hey, it's a Wes Cooley..
Offline Bankerdanny
« Reply #33 on: June 13, 2019, 11:26:47 AM »
Thanks, the etching primer in the photo was just step one over the bare metal, there will be several layers of primer to go, including high build, before I lay down the basecoast. Eastwood Company has a store in the Chicago area, so I can get 2-pack primer from them, they are also my source for spray clear.
« Reply #34 on: June 14, 2019, 05:40:26 AM »
Hours of work ruined because I didn't make sure my tank was stable on the table where it was sitting while I did a valve adjustment. The results are below.
I dropped Dorothy's tank back in the day - I feel your pain.
Online RAFster122s
« Reply #35 on: June 14, 2019, 07:52:22 AM »
I have been a dumbass too, I bought a usable but severely dented tank for my CX500 as the PO put a liner in the tank that came with the bike and it was failing. So, I stripped it and was rewarded with the discovery he had allowed a huge pool of liner setup in the back roof of the tank. I was rewarded with a loose chunk of liner bouncing about in the portion of the tank closest to you when on the bike. Thus the purchase of a beaten up tank.
Well, back to the beaten up tank...I had placed it atop a tall stack of boxes and unevenly loaded stack of things piled on top. Said stack took a tumble as it was on the corner and the tank received a pretty nice dent on top. Shame is if the tank were not dented it would be a perfect tank as inside it looks brand new. The dent in the rear right corner is severe, enough so that the metal is creased inward in a sharp edge on both the outside edge and the deepest part of the dent about a half inch inward.  I had no intention of repairing the tank,merely bought as a usable tank for while I could sort out the original tank's huge chunk of loose liner...
So, I understand the feeling you had when the tank took its tumble.
David
Offline Bankerdanny
« Reply #36 on: June 14, 2019, 08:40:17 AM »
Last night I did another 90 minutes of sanding and prep finished off with 2 coats of sealer. It is as ready for paint as I have time for. I am busy tonight and most of Saturday then flying to NYC Sunday morning ahead of a couple meetings Monday then flying home late Monday evening. That gives me ~3 days to repaint, sand and buff before Motoblot 6/22 and 6/23 and before leaving for my 2 week road trip on the 23rd or 24th that take me down to NC, SC, TN (including a ride on The Dragon) and back home through Lexington for AMA Vintage MC days July 6-7-8. And in addition to painting I am going to swap out the front master, track down an electrical short and install my bar fairing and Shoie bags. Oh, and work my regular job. Man, I am exhausted just typing all this.
Maybe I will try strip and paint job #3 next Spring, but for now I have lots of riding to do this year and so it is time to get to it.
« Last Edit: June 14, 2019, 08:46:12 AM by Bankerdanny »
Offline 7
  • Oh so green
« Reply #37 on: June 14, 2019, 08:56:58 AM »
I did something very very similar. My heart sank. Luckily the dent ended up being smallish but it still makes me feel humble whenever i see it.
'75 CB550K
Online RAFster122s
« Reply #38 on: June 14, 2019, 09:28:26 AM »
It is looking really good Danny!
David
Offline corniglio
« Reply #39 on: June 18, 2019, 01:29:20 PM »
i too am in the dumbass club..after all my hard work painting the tank, my son knocked it over while the decals were drying in the house.  took the wind out of my sails and just starting to get back into it after a few months of crying.
Offline Bankerdanny
« Reply #40 on: June 18, 2019, 01:32:41 PM »
You just have to shake it off. I have most of the priming done and should lay down the base coat tonight with color tomorrow and Thursday, clear on Thursday and wet sand and buff Friday.
Offline corniglio
« Reply #41 on: June 18, 2019, 01:47:00 PM »
im ready now..i bought another tank off ebay and will give it a go.  i'll keep the dented tank to remind me of the pain.
Offline texianbiker
« Reply #42 on: June 18, 2019, 02:46:55 PM »
Best you be dusting off your checkbook and dabbing at the tears that'll be in you eyes cause the fix is gonna be damn ugly amigo.
Offline Tews19
  • I am no
« Reply #43 on: June 18, 2019, 03:21:40 PM »
#$%*ty about the dropping of the tank but hell of a recovery to repair it Danny.
1970 Honda CB750 survivor.
Offline Bankerdanny
« Reply #44 on: June 18, 2019, 03:58:54 PM »
Whose fix?
Offline Bankerdanny
« Reply #45 on: June 20, 2019, 01:28:09 PM »
Basecoat down and color on the side covers (going to solid blue rather than gold centers with blue edges). Some color will go on the tank today along with a midcoat of clear. Then the rest of the color and full clear tomorrow.
I'll add some pictures later tonight.
Online RAFster122s
« Reply #46 on: June 20, 2019, 04:11:25 PM »
Congrats on getting this far Danny!
David
Offline Bankerdanny
« Reply #47 on: June 21, 2019, 06:52:25 AM »
Maybe I'm wrong, but this doesn't disappoint me at all
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #48 on: June 21, 2019, 10:53:23 AM »
What is wrong with it? You shouldn’t be
Offline Tews19
  • I am no
« Reply #49 on: June 30, 2019, 07:19:03 PM »
Looks great Danny. Will yiu be attending RA at the end of the month for the vintage races?
