Author Topic: M-unit - config button/kill switch problems  (Read 2882 times)
Offline w-nolan
« on: June 12, 2019, 04:24:14 PM »
Cb550 Cafe - m-unit v2.  M-switch mini 5 button plus a config button.  Cali has already reviewed and blessed my wiring diagram.  OEM Keyes switch.  Just got the bike back together in May was running great
Was tinkering around chasing a charging problem and so somehow I ended up shutting down  the m-unit.  I rechecked the connections - power and ground are solid.
The only thing I did different was I Used the config button as a kill when testing the charging ststem components.  At this point:  when I turn the key on three light race around the M-unit counter clockwise.  The rear brake light blinks as well.  Starter does not activate.  I have tried to do a factory reset based on what the guys from Revival suggested .  Hold config button for 10s in the set up menu.  This did nothing.  I have also disconnected both mainpower & ground and reconnected hoping it would reset but still no change.  next I plan to completely disconnect and test and reconnect but I’m skeptical.
Offline w-nolan
Re: M-unit - config button/kill switch problems
« Reply #1 on: June 13, 2019, 09:44:19 AM »
Great thanks - I'll give it a try.
Your the man!
