Author Topic: Valve spring tool to remove valve spring with engine in frame  (Read 1806 times)
Offline Craig Sharp
Has anyone made a tool for removing the valve springs with the engine in frame? Both lower frame tubes are removed and compressed air will be in the cylinder.
Thanks in advance.
C#
Offline calj737
  • I refuse...
Re: Valve spring tool to remove valve spring with engine in frame
« Reply #1 on: June 17, 2019, 06:22:26 pm »
The best trick I’ve seen is to stuff thin cotton rope into the cylinder, rotate that cylinder to TDC, rap on the retainer and remove the keeper. You can do this only to replace springs one cylinder at a time. Else, you run the risk of dropping the valve into the chamber deep enough to damage the guide or seat with the stem.
Offline jgger
« Reply #2 on: June 17, 2019, 08:08:07 pm »
^^^^+1 That is the BEST way to do it without removing the head. Just remember to leave a long enough piece hanging out of the plug hole to pull the rope back out. (Sorry, I had to state the obvious) ;)
Offline flatlander
« Reply #3 on: June 17, 2019, 11:27:56 pm »
yes that will work.
then if you wonder how to get them back on... you can make yourself a contraption like this:
from these parts:
- piece of tube, cut out to give access to the keepers
- something as a lever (tyre iron in my case)
- something to be used as a fulcrum for the lever
- 6mm bolt to fix fulcrum to head
- piece of rope to hold fulcrum down
« Reply #4 on: June 19, 2019, 06:52:28 pm »
 Air works fine except it wants to turn the motor sometimes, I'm thinking something like a pickle fork with a pivot off the rocker shaft.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #5 on: June 19, 2019, 08:12:35 pm »
I have one that attaches on the rocker arm pivots; a length of rope in the combustion chamber and voila! I will look for it under my bed to get you pics
« Reply #6 on: June 19, 2019, 09:10:41 pm »
Why not lifting the head? Leaking seals?
Easy with frame kit.
The seats might need a cut or valves to be lapped.
Offline turboguzzi
« Reply #7 on: June 20, 2019, 04:48:36 am »
once you had the rope inside, use this
https://www.ebay.it/itm/141984046475
being a bit if an el cheapo, built myself a similar tool. works a treat!
Offline flatlander
« Reply #8 on: June 20, 2019, 04:51:59 am »
yes also the stuff i showed above is an awful lot cheaper... just cobbled together from stuff that's been lying around :)
« Reply #9 on: June 20, 2019, 08:52:24 am »
 For insertion into the plug hole, I've also used a quality silicone jacket plug wire. It pushes easier. My big block chevy uses a spring compressor that bolts down and screws over the retainer for install/removal.
  • Gusto mo titi ko?
    • project
« Reply #10 on: June 20, 2019, 02:37:14 pm »
