Author Topic: Oil light immediately after running  (Read 788 times)
Offline Sething
« on: June 22, 2019, 08:20:32 AM »
My oil pressure light turns off when running but turns on immediately after turning off the engine. Any ideas why it’s not holding pressure after running?
Honda 1977 CB750K
Re: Oil light immediately after running
« Reply #1 on: June 22, 2019, 08:22:41 AM »
Doesnt mean its not holding pressure, which only happens for a second or two anyway, but could be switch operating pressure altered with age
Offline Sething
« Reply #2 on: June 22, 2019, 08:28:06 AM »
It is a new aftermarket switch. I could put the old one back in because I don’t think anything is wrong with it. (I originally thought it was broken but was due to a different issue). but it’s a pain in the ass under those carbs.
Honda 1977 CB750K
« Reply #3 on: June 22, 2019, 09:21:16 AM »
Frequently aftermarket ones are car ones that fit and car ones definately work at different pressures, as long as its off when running everything should be ok
Offline Sething
« Reply #4 on: June 22, 2019, 10:24:38 AM »
This puts me more at ease. Thank you!
« Reply #5 on: June 22, 2019, 11:43:31 AM »
That's is normal for me, both my CB750's lit oil warning almost direct at ign off.
Oil pressure gauge is a good modification that will show how the pump works and oil  behavior that will change when really hot. Visible when riding, just a quick look now and then.
If oil pressure will lit/flicker at idle when engine is really warm, invest in new rotors as forum member MessnerMoto has done and sell.
http://forums.sohc4.net/index.php/topic,173081.0.html
Offline Sething
« Reply #6 on: June 22, 2019, 12:07:16 PM »
Good to know about the rotors. I was considering a pressure gauge if I became too worried.
Honda 1977 CB750K
Offline pushin9s
« Reply #7 on: June 23, 2019, 04:21:55 AM »
Slightly different animal, but my 350F oil light comes on pretty quick after stopping the engine.  I just turn it off with the key switch so I don't worry about it anymore.
(Oil light used to flicker then come on steady at idle after only 15-20 minutes of riding.  Replaced the OEM switch with one from 4into1 and it stays off anytime the engine is running.)
