Author Topic: 1977 CB550k Rebuild Questions  (Read 1029 times)
Offline kakon864
« on: June 28, 2019, 08:41:16 AM »
Hi all,
I am rebuilding a 77' CB550. It only has 19k miles on it, but the PO left a spark plug out and it was sitting under the eves, so the number 2 cylinder was seized and has some rust build up. I honed all the cylinders, but the one that had the rust build up has very shallow pitting (see attached photos) that you can feel when you run your finger over it. I'm not sure if I should try honing it some more or just leave it. I was going to use the 4 into 1 full rebuild kit along with a new cam chain (had to cut the old one since it was seized). Another concern I have is the primary drive chain seems a little loose, so I am not sure if I should replace that or not while I have it apart. Other than that one cylinder it seems to be in good condition, although I have not checked the valve seats or guides yet.
My questions are:
1. Is the 4 into 1 rebuild kit high quality?
2. What should I do about the number 2 cylinder?
3. Is the Primary Drive chain too loose?
4. What is the best endless cam chain that I can buy that is not super expensive?
Also is there anything specific to this engine or Honda's that I should know when rebuilding it? I've rebuilt cars and Yamaha bikes, but this is my first Honda.
Thanks in advance  :D
P.S. most the the black-grey in the picture is staining, the actually pitting is not very wide spread.
https://imgur.com/a/nTSthD3  -Primary Drive chain video
1977 Honda CB550k
1978 Yamaha Dt250
1979 Yamaha XT500
1973 Kawasaki G5 100
Offline 540nova
Re: 1977 CB550k Rebuild Questions
« Reply #1 on: June 28, 2019, 08:45:58 AM »
Hi all,
My questions are:
I will
 just got home kkkkk
N no nn it on no
Sent from my Pixel 3 XL using Tapatalk
« Reply #2 on: June 28, 2019, 02:32:31 PM »
Sorry but that needs a rebore to run properly and any play in a primary chain is too much on the 500/550 as the chain when loose eats into the main oil galleries. Do change the 8 cush rubbers in the primary drive/starter unit as they are over 40 as well, age does more damage than mileage.
Offline kakon864
« Reply #3 on: July 01, 2019, 08:47:05 AM »
Any recommendations for a cam chain and primary drive chain?
1977 Honda CB550k
1978 Yamaha Dt250
1979 Yamaha XT500
« Reply #4 on: July 01, 2019, 09:02:14 AM »
Dave silver
Offline kakon864
« Reply #5 on: July 01, 2019, 09:52:58 AM »
Dave silver
Cool website, Thanks!
1977 Honda CB550k
1978 Yamaha Dt250
1979 Yamaha XT500
« Reply #6 on: July 01, 2019, 10:02:31 AM »
You can look up part numbers on cmsnl then search Silvers by part number, its cheaper for you now he has a US wharehouse
