Author Topic: swapping rims  (Read 778 times)
Offline dave the welder
  • dave the welder
swapping rims
« on: June 30, 2019, 01:44:12 PM »
can anyone know if the rims from a 77 750 matic will swap onto a 71 cb 500 without any probolems.just discovered the brand nos tires are a pos.thanks as we are trying to get it ready to take to ohio next weekend
don't buy it build it
Offline Scott S
Re: swapping rims
« Reply #1 on: June 30, 2019, 02:32:26 PM »
 Not a direct swap. Anything is possible but you'd have to make axle spacers, etc.
 Or are you talking about lacing the hoop to the 500 hub?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
  • dave the welder
Re: swapping rims
« Reply #2 on: June 30, 2019, 04:46:24 PM »
Not relacing direct swap.thanks
Sent from my SM-G965U using Tapatalk
Offline Bankerdanny
  • Endeavor to persevere
Re: swapping rims
« Reply #3 on: July 01, 2019, 07:51:07 AM »
The front should swap direct. The back may take some effort,  but it should be doable
Re: swapping rims
« Reply #4 on: July 01, 2019, 08:29:29 AM »
If the matic has the 450x17 tyre forget it as its too wide for the swingarm
  • dave the welder
Re: swapping rims
« Reply #5 on: July 02, 2019, 07:09:10 PM »
Well the front was a direct swap but you must use the 500 rotor(smaller dia).now the rear was a no way in hell fit. the 750 swingarm was 1 inch (aprox)wider then the 500 swingarm.thanks for input.hopefully new tires arrive tomorrow so we can ride in Ohio
