Author Topic: Cb750k oil cooler mounting - SOLVED, SORT OF?  (Read 804 times)
Offline Dolomite
  • I'm 40% Dolomite.
« on: July 01, 2019, 06:18:05 PM »
Picked up a nice original Lockhart oil cooler kit with all the fittings and sandwich plate. However, the mounting is leaving me a bit perplexed. The horizontal bar below the horn mounts is the obvious point, but the exhaust headers would block one of the oil lines. Going higher and mounting to the Y section coming from the neck creates multiple mounting issues with cables and wiring. Almost tempted to line it up on the Y and just drill and tap the frame and bolt it directly. Any suggestions or examples would be great, thanks in advance!
« Last Edit: July 05, 2019, 06:33:43 PM by Dolomite »
Offline BenelliSEI
  • 1969 cb750
Re: Cb750k oil cooler mounting
« Reply #1 on: July 02, 2019, 07:18:23 AM »
Dolomite....... for mounting coils, accessories and oil coolers, i’ve had good success using stainless hose mounting clamps. Any good hydraulics shop has a huge selection. If you measure the OD of your frame tubing and find the right clamp (the best ones have a rubber cushion on the inside), you can mount a bolt/nut through the tab hole on the clamp. Makes a supper neat installation, with no modifications.......
Offline Dolomite
  • I'm 40% Dolomite.
« Reply #2 on: July 05, 2019, 06:33:21 PM »
Ended up going a unusual route, got a set of roll cage/ light bar mounts. I will be plumbing it tomorrow, I think the larger mounts provided a good offset away from the exhaust.
