Author Topic: Chrome 836 Tracy Project! (Sold 04/15/2023). It was fun!  (Read 174116 times)
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: My new 836 Tracy Project!
« Reply #125 on: June 13, 2007, 10:23:18 PM »
Thats what I'm talkin bout!!!!!......is that Gordon's frame kit there ya got chromed?? Very nice!!!! Been meaning to ask you Seaweb.....did you ever get your fork brace from Terry? I'm wanting one too and wonder if it makes a difference.Let me know.
The entire frame is chromed, the kit has been tig welded in. I will take some closer photos of the installation later for those that might be interested in putting your own in. (I know some guys still have it sitting on a shelf ;D)
The guys who did the frame work were a VERY small shop I was turned on to by my Chopper buddy on Island.
The shop looked like #$%* which scared me a bit, but I came around after about 10 mins.  I'm pretty good at being aggressive enough when I want to do business, that you WILL NOT attempt something for me unless you have passed the 3 question test.
TEST:
#1 Are they going to approach this job with enthusiasm?       "always try and make them feel like THIS job is very important".
#2 Are they approaching this job with Exuberance?               "Do they really want the job? Excited? "
#3 Are they approaching the job with unbridled Experience?   ""Can they do it with my confidence?"
$400.00 bucks may seem a bit steep, but it was 3 1/2 hours for the frame cut/weld,  also fixing/welding the bent steering lock and cut off the center stand hardware on the frame. All I know is"I cant weld yet"  and it looks like they did a job well done.
Now as for your question about Terry..........................
That was 6 months ago.............where are ya dude?  The 78 forks? The 72 forks?  I'm not fussy ;D
I did start this fork brace madness in you did I not?
How do Canadian dollars compare to US ones ?
Sam.
        (decimals have now been moved)
The costs of parts would be in US dollars. The CDN and US currency is almost at par. $1.10 CDN for a US $1.00
Basically the same-$670.00
« Reply #126 on: June 13, 2007, 10:48:02 PM »
When has $110 been the same as $1.00 and were dose the $67.00 come into it ?
Sam. ???
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #127 on: June 13, 2007, 10:57:04 PM »
Decimal point has now been corrected above.
Total cost approx $7275.35 US  thats   727.50 at 10% exchange ,  Its not $670.00 anymore, I have been modifying & adding costs up above in thread :o
« Reply #128 on: June 13, 2007, 11:03:37 PM »
Ya wouldn't really wonna know what the CR has cost would you, it looks like a telephone number complete with the international code ;D ;D
$24,400.00 US  :(
Sam. ;)
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #129 on: June 14, 2007, 12:25:17 AM »
My parents are still spending my inheritance, why should I be any different?
« Reply #130 on: June 14, 2007, 05:15:49 AM »
Good luck Seaweb with the rebuild and you know we are all keen to see (and hear) the finished product!! I also appreciate the shopping list you put together so thanks for that as well.
good luck!
Andy
Offline Hondell
  • Just an easy 1000 Hr. resto
« Reply #131 on: June 14, 2007, 08:54:37 AM »
Hey Seaweb , here is my 836 Tracy project from Edmonton. We should get together all the Tracys in the west someday!
Rick
1972 Cb750 resto- 1972 Cb750 stoplight racer- 1972 Cb750 vintage touring - 1979 CBX- 1982 Kaw GPZ- 1968 Honda SS125A
Offline mrbreeze
  • Not your average
« Reply #132 on: June 14, 2007, 08:38:40 PM »
TEST:
Sam.
Yeah....I know the frame is chromed and then you discovered the neck was bent!! Did you ever get any satisfaction from the guy that sold it to you? So now you have spent  to have the neck straightened out. What I am wanting to know is how much did it cost to have someone install Gordon's kit plus chrome it. I also have the kit but I want to hang on to it for a future project.
MEMBER # 257
Offline CrisPDuk
  • Christ on a bike! Me, an
« Reply #133 on: June 14, 2007, 08:54:57 PM »
Correct me if I'm wrong Seaweb, but I'd say the frame hasn't been rechromed, the welded in kit looks like uncoated steel to me
To rechrome it to the xisting standard would cost a small fortune :o
1978 CB550 K3
1985 H100S
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #134 on: June 14, 2007, 09:36:36 PM »
Breeze, do you have you a different kit?
Mine just had the end pieces, you cut the existing frame and slide the pieces into "mine chrome" "yours black" and tig them in place.
Same frame, just with the added slip fitings.
Look at your kit and look at my photos again. I don't think you got the frame with yours did you?
Frame Mod kit cut/weld/install $400.00
Offline RRRToolSolutions
  • I love old Japanese bikes!
« Reply #135 on: June 15, 2007, 04:56:07 AM »
Derek, I just noticed - there is a huge problem. They messed up the install. They have left off the front inserts and removable section. This is critical for clearance of the head cover. I had to design that in there in order to give the stock key mount location and keep the kit hidden under the tank. What they have done is left those pieces off not realizing it's purpose. You will not have the clearance to lift-off the cover and remove the head. Trust me, I've learned the hard way - doing it twice. I measured and worked out the specs for the kit carefully. What is worse, they would have had to take the threaded rod out of the front joints because I "Red Loctite" those grade 8 threads into the joints for the very reason they are not removable. Call me.
Have a look - Regards,
Gordon
« Last Edit: June 15, 2007, 05:27:51 AM by Ilbikes »
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
« Reply #136 on: June 15, 2007, 06:15:49 AM »
Here is Kevin's install - You've got to have those inserts!!
http://www.sohc4.us/forums/index.php?topic=20260.msg210776#msg210776
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #137 on: June 15, 2007, 12:54:52 PM »
Crap!  Thanks for your help on the phone today. I gather you spoke with the shop. So it looks like they can fix it ???
« Reply #138 on: June 15, 2007, 02:37:55 PM »
Derek, yes he called me. He was a very nice guy and admitted that he did not know where the engine's head came to and did not know about the clearance issues. The inserts, threaded rods, and jam nuts are up inside the frame. I told him if needed anthing to call me or let you know - I'll supply it.
Yes, it looks to be an easy fix.
Keep me posted.
Regards,
Gordon
Offline mrbreeze
  • Not your average
« Reply #139 on: June 15, 2007, 09:54:06 PM »
I'm not seeing what you are but I'm bookmarking this post for later.Hope all goes well as intended.
MEMBER # 257
« Reply #140 on: June 16, 2007, 03:13:34 AM »
Fred, when you do yours be sure to follow the instructions  :)
I'll be here to help too.
Regards,
Gordon
Offline DarkRider
« Reply #141 on: July 08, 2007, 11:42:06 AM »
any progress on the Tracy?
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #142 on: July 08, 2007, 11:56:36 AM »
It's summer time.and 3 bikes that run!
Next step is re-chromeing a bunch of stuff$$$$$  I'd rather spend $$ this time of the year on Beer ;D  It just seems to nice to go into the shop ??? If I do it now, I'll have nothing to do when the rain starts again.
I'm still in need of a chrome tripple tree since my latest Ebay screw-over.
thanks for asking, I will post when I get back at it.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #143 on: September 02, 2007, 03:29:56 PM »
Still buying stuff for the build.
Any one ever tried an internal throttle or clutch set ip on a 750?
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #144 on: September 02, 2007, 03:42:25 PM »
P.S. Here are the after picts of the frame mod instal.......the 2nd time around ;D
Offline DarkRider
« Reply #145 on: September 05, 2007, 08:45:39 PM »
Lookin good derek.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #146 on: October 12, 2007, 09:02:11 PM »
Well Gents, the winter approaches. ........Time for a new one!  Picked up the frame and assorted parts in Vancouver today. It cost a bundle, but I wanted a solid platform to start with and the old chrome just wasn't up to it.
836 Rebuilt engine ready to go in this weekend, my mom is here and she said she would help as the rest of the family is out tomorrow.  This ought to be fun. Never turn down free labour.
Offline mrbreeze
  • Not your average
« Reply #147 on: October 12, 2007, 09:25:12 PM »
So you're gonna make Mom help stab the motor??  ??? Sounds like something I would do......Actually I did one day.She was standing by the bike yakking and I said " hey!!!!...when I pick this front end up.....slide this jack stand under the frame.........then haul ass to the other side and do the same!!!..................free labor is awesome!!! :D
MEMBER # 257
« Reply #148 on: October 13, 2007, 03:57:36 AM »
Looking good seaweb11.
 Your name is now probably on your chrome guys Christmas card list!
Offline bathcollector
« Reply #149 on: October 13, 2007, 05:22:54 PM »
You wouldn,t have a spare clutch cover and matching alternator cover like on your engine you want to sell by any chance ??
