Author Topic: Chrome 836 Tracy Project! (Sold 04/15/2023). It was fun!  (Read 172495 times)
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: My new 836 Tracy Project!
« Reply #225 on: December 22, 2007, 03:54:48 PM »
Thanks mkramer ;D  and Terry ;)
I want to get the "in behind" stuff all done before I instal the swing arm for keeps.
P.S. any one have a quick link to an online supplier of hose?  I hate to leave the Island ;D
.....only once in the past 2 months :o
« Reply #226 on: December 22, 2007, 03:58:29 PM »
Any on-line auto parts store should carry oil cooler/ auto transmission hose (what I use for my oil cooler kits) just measure the pipe mate, it'll be either 5/16" (8mm) or 3/8" (10mm) OD. Cheers, Terry. ;D
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #227 on: December 30, 2007, 02:46:07 PM »
Oil tank all installed now permanently, had to drill out one of the mounts "broken bolt" :P.
Swing Arm Question:
Does the felt ring get put on the end of the thrust bushing and then installed or do I push the felt ring into the arm 1st up against the pivot bushing, then put on the thrust bushing?
Clymer Honda 69-78 Manual  page 165 at the bottom, figure (7)
Thanks for any help, trying to get this done today.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #228 on: December 30, 2007, 04:17:04 PM »
I see you all reading ;D  throw me a bone........
Offline DarkRider
« Reply #229 on: December 30, 2007, 05:33:34 PM »
sorry derek...dont even have a milk bone to throw ya. lol
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #230 on: December 30, 2007, 05:39:44 PM »
it seemed to me an easy question for anyone who re did their swing arm recently :-\
My last one like this was 3/12 years ago and I probably did it wrong then ::)
« Reply #231 on: December 30, 2007, 05:40:01 PM »
My shop manual is VERY vague. "apply a liberal amount of grease on the pivot collar and assemble it into the rear fork. Insert the pivot bolt from the right side while holding the dust seal caps on both sides of the rear fork, and then install and tighten the 14mm self lock nut."
The picture shows the rear fork pivot bushing going in first, the felt ring next, the pivot thrust bush next, then the dust seal cap, washer, then self lock nut.
Hope this helps.
Jerry
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #232 on: December 30, 2007, 05:47:24 PM »
Thanks. I read the same thing. There is a groove just inside the swing arm that the felt would go into allowing the thrust bushing to be flat against the arm when it is pushed on. my felts are a bit big now that I tried it the other way.
2nd way. slip felt over the ridge on the thrust bushing and then install. The felt would now act as a cushion of sorts between the end of the swing arm and the trust bushing.   Does that make any sense?
I'm still looking for the right way..anyone?
Offline RRRToolSolutions
  • I love old Japanese bikes!
« Reply #233 on: December 30, 2007, 07:56:40 PM »
Derek, I was in my shop working on a Kaw triple and missed your post - I've got my first broken crank I've ever seen.
Anyway, my parts fiche shows -
Working from the inside to the outside -
1)  07 BUSH, RR. SWINGARM
52108-300-300
2) 12 RING, RR.
52145-283-000
3) 08 BUSH, RR.
52109-283-300
4) 11 CAP, DUST SEAL
52144-283-010
Regards,
Gordon
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
Offline cleveland
« Reply #234 on: December 30, 2007, 08:15:05 PM »
I'm not sure how I missed this thread.  ???  Looks too sweet for words!   8)
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #235 on: December 30, 2007, 08:37:15 PM »
Thanks. I have figured out which order they go on. Still no clear answer on the felt ring.
stuff the felt into the arm 1st bushing would then be flush when put on.
 or lay it around the thrust bushing? becoming a cushion.
Either way it goes in 1st, just where exactly........?
One is now broken, both are stretched out  ::)
100 views today by members, no one ???.
« Reply #236 on: December 30, 2007, 10:03:50 PM »
My vote is your 1st picture - stuff it in first. This way it acts as somewhat of a lubricating seal. Seals between the 2 bushings and between the bushings and the swing arm pivot bolt all the while lubricating the pivot bolt and keeping crud out?? Clymer's, Chilton's, nor Honda's manuals do not help BUT, at least, I discovered I don't have this felt seal on my F thank goodness!
BUT, on the other hand, I can not say for sure.
Hondaman, oh Hondaman, where for art thou?? Your swing arm intelligence is needed.
« Last Edit: December 30, 2007, 10:18:08 PM by RxmanGriff »
Offline cleveland
« Reply #237 on: December 30, 2007, 10:41:03 PM »
It defiantly goes in first, no question about it.
I was thinking of replacing it with a rubber o-ring .  Think thats a bad idea?  ??? Would that even work as a barrier against the grease?
Did you just cut some felt to make a new one?
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #238 on: December 30, 2007, 10:42:59 PM »
Rx, Clevland,  that was the way I was going to go tomorrow with out any more input . Thanks.
I think the next time I remove my 78 swing arm, I'll take a look, but I don't remember them felt widgets :o
I got the felts on Ebay at some guys online store selling the caps & felts together. Sorry can't remember the vendor. :-[
here are a couple threads on changing them over to rubber. "I did search first" ;D
http://forums.sohc4.net/index.php?topic=21778.0
http://forums.sohc4.net/index.php?topic=2697.msg19449#msg19449
« Reply #239 on: December 31, 2007, 03:57:02 AM »
I got mine from Honda - still available. They were in late 2006.
Gordon
Offline bert96
  • past ride
« Reply #240 on: December 31, 2007, 08:34:33 AM »
 Hey seaweb,will you try to fit your fork brace you bought on ebay not to long ago???
 i'm asking because i have the same brace and i would like to see how you would do ;D
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #241 on: December 31, 2007, 09:47:18 AM »
They are far to big, I just bought another one on Ebay a couple of weeks ago, it should bolt right up.
Offline bert96
  • past ride
« Reply #242 on: December 31, 2007, 10:16:26 AM »
 Is this one made for the CB or is it made for another bike ?
Offline bert96
  • past ride
« Reply #244 on: December 31, 2007, 10:31:21 AM »
  thanks for the info!
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #245 on: December 31, 2007, 01:35:43 PM »
Thanks again guys, just had to wrap my head around that one a bit.
Swing arm final instal finished ;D
There will be more questions to follow I assure you. ::)
Just have to keep picking away at it a bit every day. ;D
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #246 on: January 05, 2008, 07:04:21 PM »
Polish, Polish and a bit more put together.
How do I take the front brake pivot arm out to lubricate it?  One of them was fine the other is VERY stiff! I did get the top off ;D "I tried a search, no could find"
P.S. I now realize one of my forks is longer/shorter than the other one. :o
The only thing I can think of there is that I bought one of the tubes from" sirg" and it must have not been correct it was off a 75F???  Any one have a good fork tube for a 72K?
« Reply #247 on: January 05, 2008, 08:48:44 PM »
G'Day Derek, the pivot pin on the brakes should just push out, but if it's stiff you may need to carefully tap it out with a soft aluminum or copper drift, then clean it up on a wire wheel and use some good grease or anti sieze compound.
35mm fork legs come in different lengths, depending on the model they come off. F2 fork legs will work, but they're longer, as are K7/8 legs, and I think 900F legs are longer again. I used Suzuki GS750 tubes (better dampers) on my K1 and they were a good inch longer than the K3-6 legs I'd been using prior.
Your new fork brace isn't a fork brace as such, it's a chopper "Tweek bar" that clamps onto the extended fork tubes (not the sliders) on a chopper about half way between the lower triple and the front wheel, to reduce fork flex. Sadly it won't do you much good on a normal bike, it'll just reduce your fork travel, with a thump. Cheers, Terry. ;D
« Reply #248 on: January 05, 2008, 08:57:39 PM »
Keep telling you those are 73 and up forks..
 Trying to get started on the damn_per brackets.. will work on them a bit tommorow.. ..good news is I am only about 1500 pcs behind to make!!.. but it was 2000 Friday AM..
« Reply #249 on: January 05, 2008, 09:01:34 PM »
Correct, they're K3-K6 forks Derek. ;D
