Author Topic: Chrome 836 Tracy Project! (Sold 04/15/2023). It was fun!  (Read 169688 times)
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: My new 836 Tracy Project!
« Reply #275 on: February 11, 2008, 01:34:25 PM »
What am I missing here?  I did not take photos when I took off the rotors, but the speedo piece was in there some how.  Looking at another single rotor wheel, it seems to need  a piece with the corresponding slots to make the speedo rotate. Have I lost a piece?
Offline GoatBaSS
  • Could someone find an
  • To weird to live, to rare to die.
« Reply #276 on: February 11, 2008, 02:21:47 PM »
Outside right with tube on bottom. It clicks in and the spacer on the axle keeps it in place. First wheel pic should be it. The spacer on the speedo housing fits inside for it to line up.
Leethal # 3046?
1972 CB750K/900CC Red Headed Dunstall, 1975CB750FSS Gone BNF: 1974CB500T, 1976CB750K X 2
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #277 on: February 11, 2008, 02:41:56 PM »
OK, I read that 4 times and get most of it.
It does indeed slip into one side, sorry for the confusion there, but there is nothing there for it to grab hold of to make the inside spin?
I'm including the only photo I have before tearing it down.
« Reply #278 on: February 11, 2008, 03:09:48 PM »
Derek,
Check your email for a front wheel diagram. Much easier for me to send emails than downsize pix and attach here. Which one of the buttons above do you use to add a link to Photobucket?
Jerry
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #279 on: February 11, 2008, 03:14:09 PM »
No button. you just copy the bottom html from your photobucket pic. and paste it where you would normally be typing on the forum box
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #280 on: February 11, 2008, 03:28:24 PM »
RxmanGrif Still looking at pdf you sent.
So am I missing #3?  I assume #2 is replaced with my 2nd rotor?
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #281 on: February 11, 2008, 03:31:46 PM »
In the reply mode, click on this icon and insert the photobucket HTML string between the delimiters.
« Reply #282 on: February 11, 2008, 03:59:49 PM »
SOMEWHERE in my garage is a speedo drive assembly. SOMEWHERE! I found my hub at least. I BELIEVE (less than 99.9% sure and other key words are capitalized) the top "tab" on #3 (gear box retainer) fits over the flat spot on the hub and the notched recesses on it's outer "lip" line up inside the speedo gear box #7. EUREKA, well almost. Not giving up. Found the other pieces but the gear box is still MIA. YES!! All the pieces. Disclaimer: both sets I have (on bike 75 750F & spare) are SIMILAR to the picture but #3 does not have the tab that bends toward the hub. They have 2 tabs that fit under and are held in place by the chrome retainer cover #2. ANYWAY, the protruding part of #3 has 2 notches on it that fit over 2 tabs inside the gear box.
Do any of my ramblings make sense>
Bob,
I didn't think us old guys knew this fancy technology as well as you. Thanks. HTML string & delimiters! I'm pretty impressed. Guess I must be the old guy now  ;)
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #283 on: February 11, 2008, 04:48:10 PM »
"Do any of my ramblings make sense?"
Not sure?   Are you saying I do have something missing and you have the parts?
« Reply #284 on: February 11, 2008, 04:56:19 PM »
Damn! I can't open photobucket pics from my defence department compuker! And I've got knowledge virtually dripping off me too! Bummer! ;D
Offline mkramer1121
« Reply #285 on: February 11, 2008, 05:37:16 PM »
Derek,
If you can wait until I get home, (oh, 4 hours or so), I can verify how it assembles.  I believe, from wheel out to the right side, it goes disc, gearbox retainer (the wings go against the wheel), the silver circular metal piece (cover) that holds it to the wheel (the grooves face inside, lock the retainer down, this has hole for the rotor bolts), the paper washer, then the speedo.  See the attached pic:
« Reply #286 on: February 11, 2008, 06:21:51 PM »
I do not know how a double disc set up works with that or other wheels. Item #3 gear box retainer in the diagram I emailed turns the speedo gearbox. It is not in any of your pictures. I wish I had a spare but do not.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #287 on: February 11, 2008, 06:53:25 PM »
mkramer1121: so in your diagram I'm missing 8,9 and 11 :-\
Offline mkramer1121
« Reply #288 on: February 11, 2008, 08:47:28 PM »
8 is not needed its just a paper seal to keep grease in.  I probably have those parts in my garage, I'll need to dig, but if I find them, they are yours, the earliest I can look is Thursday night though.  I went w/ a GL front end on mine, using that speedo and such, so I think I still have the 750 ones somewhere.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #289 on: February 11, 2008, 09:04:08 PM »
Thursday!!!!!!!!  That's Outrageous !!!!!
....OK I'll wait. Thanks ;D  ..........Man I love this place. ;D
and Terry I hope you caught that drip :o
Offline mkramer1121
« Reply #290 on: February 11, 2008, 09:13:22 PM »
Well, with class Mon, Tues, Wed and a fulltime job, what do you expect!   ;D
« Reply #291 on: February 11, 2008, 10:12:17 PM »
You still going to pole dancing classes Mike? ;D
Offline mkramer1121
« Reply #292 on: February 12, 2008, 04:55:15 AM »
only for you Terry....
« Reply #293 on: February 12, 2008, 08:54:33 PM »
Well don't forget to send me the pics! ;D
Offline mkramer1121
« Reply #294 on: February 12, 2008, 09:28:10 PM »
I'm the one on the right... ;D
gotta love Chris Farley RIP
« Reply #295 on: February 12, 2008, 11:37:54 PM »
Yeah, he was great, just a pity he was dropping acid, and not diet pills.............  ;D
« Reply #296 on: February 13, 2008, 08:47:39 AM »
That Chis Farley Skit was the best.. I like when Sayze says, I know you should win it you are the best!!
Derek, will send your fork today..^&*&^%$%^& aftermarket fork and its oversize chrome!!. will send exhaust stuff too..
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #297 on: February 22, 2008, 07:52:35 PM »
Had a bit of graphic interface down time. I think I have that sorted now. ;D
Seat came in and I am ecstatic. It is exactly what I wanted. The leather on the corners look grey in the photos but is in fact a perfect match to the cayman skin ;D
Got my bent fork back from 754 and started on a front end mock up. Also received a chrome headlight bucket I bought on line.
I think it looks goofy, unless I add a fairing to this bike, which is a high probability.  What do you think?
Just trying on an old fairing.......Cut way down, it may work????????
fuzzybutt
« Reply #298 on: February 22, 2008, 10:01:41 PM »
that does it, i'm going to have to do dual discs on my 74' 750k. bike is looking AMAZING by the way
Offline CrisPDuk
  • Christ on a bike! Me, an
« Reply #299 on: February 23, 2008, 03:10:10 AM »
Looking good Seaweb 8) That seat's definitely a love it or loathe it thing though :-\ ;)
Painted to match the Tracy body that fairing should look pretty cool ;D
Damn you and your shiny calipers though >:(  I took one look at all those grooves and corners on mine, then chickened out and repainted them, Now the look of yours is making me think maybe I should be getting the paint stripper out ::)
1978 CB550 K3
1985 H100S
