Author Topic: Chrome 836 Tracy Project! (Sold 04/15/2023). It was fun!  (Read 169685 times)
Offline Hush
Re: My chrome 836 Tracy Project!
« Reply #375 on: May 29, 2008, 04:56:57 AM »
Mines an old cop bike so the controls have all sorts of extras like lights and sirens and mike, I had to disasemble the left hand control just to take it to the wreckers so he could get me the correct clutch lever, of course nothing wanted to go back in where it all came from.
Its like some kind of devil spawn jack-in-a-box when springs fly freely across the shed.
The right hand control has even more complex switches and even though I tempted to crack it open so I can figure out the wiring for the lights and sirens I've decided to just track them through the birds nest of wires inside the headlight.
I'm sure half of them are just loops put there to confuse us! ;D
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #376 on: June 10, 2008, 01:38:22 PM »
Sooooooooooo new controls arrived today.
The right side has just one hole for the throttle! I need push and a pull holes?
Looks like I could just skip the push side.
P.S. Should these speedos work on a Honda 750?
http://www.mikesxs.net/mikesxs-accessories.php?category_id=8.5
« Reply #377 on: June 10, 2008, 03:16:22 PM »
from what i've been told by Doug_Id those gauges work and are accurate up to certain speed, then they start bouncing a little. doug said it wasn't that big of a deal, but if you want top shelf look elsewhere.
don't know what to tell you about the cables
edit: he also said that if given a time machine he would by them again (i've come  prefer the really huge stock gauges myself)
« Last Edit: June 10, 2008, 03:19:49 PM by spikeybike »
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #378 on: June 11, 2008, 02:21:14 PM »
Received an email from Mikes XS
Will these spedos work on a Honda 750?
"No, they are made for the XS650 Yamaha only."
« Reply #379 on: June 11, 2008, 03:04:30 PM »
hmmmm. i think doug must have gotten them from somewhere else, i think JCWhitney as a set just like those.
strange ,... i wonder who in this , is misinformed
Offline DarkRider
« Reply #380 on: June 11, 2008, 03:33:29 PM »
Are you looking for a pair of mini guages derek? why not try cycle X? they have a mini tach and speedo combo that would work on your bike.
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline mrbreeze
  • Not your average
« Reply #381 on: June 11, 2008, 08:14:32 PM »
So what do you think of the controls Derek? I see you mentioned the lack of push cable. I haven't ran one for years. If you think that return spring might break,maybe you should have a push cable but I think that spring is more than plenty to do the job and it wouldn't be hard to pack an extra. I also bought a master cyl. from Mike's .....had to go thru some sh!t to get a throttle cable made up because of cable mounting in new Yami control. You will dig it when its all hooked up & working.....I think it will blend in good with all of the rest of chrome!!! Keep up the progress reports.
MEMBER # 257
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #382 on: June 11, 2008, 09:07:09 PM »
Are you looking for a pair of mini gauges Derek? why not try cycle X? they have a mini tach and speedo combo that would work on your bike.
Thanks, I was trying for the free shipping form Mikes at an order over $50.00 as
I was ordering some connectors for the controls.
They should work out fine........ wiring....... "color blind" :o
I agree, one throttle cable should suffice. It won't be far from home to often ;D
Breeze
Did you match up the connectors with another female or did you just cut them?  I ordered one of the connectors today, but they were out of stock on the other one I needed.  Any one have an online supply for metric electrical multi prong flat and round connectors?
Offline mrbreeze
  • Not your average
« Reply #383 on: June 11, 2008, 09:20:59 PM »
I used bullit connectors on most of the wires but did end up using a couple of flat spade connectors.As long as it is a tight connection,I'm happy.Let me know how your wiring thru the handle bars goes....I recall the left side (with the most wires) was kind of a pain.
MEMBER # 257
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #384 on: June 11, 2008, 09:24:25 PM »
No way an I going to attempt that with these bars ;D
Offline bradweingartner
  • 74 CB 550 x2
« Reply #385 on: June 11, 2008, 10:39:12 PM »
Yamaha uses a different ratio for the gauges than most other jap bikes. So, that explains the problem.
Offline Magpie
« Reply #386 on: June 11, 2008, 11:22:37 PM »
Hi Derek,
Try here http://www.vintageconnections.com/
Cliff.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #387 on: June 17, 2008, 12:33:06 AM »
Thanks for the ideas for gauges and connectors .
I will go back to cycle X for the speedo. I want a mini chrome in KPH not MPH, I'll have to go back in his site to look again.
Rear sets should be here in a few days ; ;D
 It's hard to keep on track with bike with shop build going on..........
She seems content in the house shop waiting for her new home.
mcbreeze.......check your mail at the top of the page.
Offline mrbreeze
  • Not your average
« Reply #388 on: June 17, 2008, 09:18:05 PM »
Just replied to ya there Derek!!! (Awhile ago actually!!!)
MEMBER # 257
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #389 on: July 11, 2008, 05:28:44 PM »
I've had another project going on, but I have still made a bit of progress ;D
New Tarozzi rear sets.............
Break side.............
And a bit of work on the controls.......
Offline void909
« Reply #390 on: July 11, 2008, 06:26:59 PM »
Where did you get the Tarozzi rear sets. Where they hard to mount?
knock with no answer
Offline mrbreeze
  • Not your average
« Reply #391 on: July 11, 2008, 06:53:43 PM »
Derek, Check out my new avitar.....thats my new head setup.I will try to post some better pics. I wanted to warn you.....when you put your triple trees together with new tapered bearings (I assume?)......Don't put all of your gauges,dash panel stuff on until you go out and ride it to seat the bearings. They "WILL" loosen up. Its easier to snug it up without all the goodies mounted. Your bike will rule!!!
MEMBER # 257
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #392 on: July 11, 2008, 07:04:39 PM »
Jim Hinshaw
Fast from the Past, Inc.
PO Box 606
Hoschton, GA 30548
USA
770-614-0968 voice & fax
jimhinshaw@fastfromthepast.com
www.fastfromthepast.com
Sounds like a plan ;D
Offline void909
« Reply #393 on: July 12, 2008, 01:01:07 AM »
thanks seaweb
Offline strangedaze39
  • 1972 CB350F
« Reply #394 on: August 23, 2008, 05:24:08 PM »
OMG it's beautiful, I can't believe I missed this build. Not exactly my style if I was starting from scratch, but this thing is so freaking unique, well built, and awesome looking I have no choice but to like it!  8)
Any updates on the build?
Thanks for posting this sweaweb
SD
1972 Honda CB350F
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #395 on: August 23, 2008, 05:39:03 PM »
Thanks for the nice comments.    ;D         I have been a bit busy since June.
http://forums.sohc4.net/index.php?topic=36272.0
It needed a place to be finished and parked.
Offline A Grove
  • Some people call me a
« Reply #396 on: September 18, 2008, 06:10:51 AM »
AHH! Any updates?!
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #397 on: September 18, 2008, 11:14:10 AM »
Nothing new, still buiding its house ;D
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #398 on: December 02, 2008, 07:16:57 PM »
Offline moham
  • .fnord.
« Reply #399 on: December 03, 2008, 10:58:05 AM »
Those pipes are just sick. I think I will need to buy another 750 just so I can fit some of those pipes to it...
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
