Author Topic: Chrome 836 Tracy Project! (Sold 04/15/2023). It was fun!  (Read 169679 times)
Offline dagersh
    • Photos
Re: My chrome 836 Tracy Project!
« Reply #450 on: December 11, 2008, 02:00:37 PM »
Derek,
You should check out the fairings that came on the 1976-1978 Moto Guzzi Lemans I's. Bikini fairing with 7"cut out, would definitely look the part on that gorgeous creature.
Moto 1 on this link:
http://www.motorcyclebodywork.com/guzzi/motoguzzilemans.htm
Humble opinion...
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
« Reply #451 on: December 11, 2008, 07:53:07 PM »
I appreciate all comments 8)  That last chrome fairing is awesome, but I think my cuts to what I have will work out OK.
Any one ever do this?  Wonder what the law will say?  Just muckin around. Can't get a flush mount on fairing for the signals.
« Reply #452 on: December 11, 2008, 08:00:43 PM »
Exotic in a black lipstick kind of way.  Too low to be practical though.
How about horizontally off of the lower tree clamp bolts. They would be almost in line with the rears and a little more functional.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #453 on: December 11, 2008, 09:33:26 PM »
Sounds good. Now I need to fab up a couple of side chrome brackets  ;)
I figured if I put out a bad design, someone would chime in ;D  I knew it wouldn't pass inspection, just got a bit frustrated today.
"Breeze", what did you do to sort out your throttle cable issues with your Yam controls?
Offline mrbreeze
  • Not your average
« Reply #454 on: December 11, 2008, 10:22:36 PM »
Glad you asked Derek........I was about to start bugging you about wiring the controls and how that worked out. I went to a Yamaha dealer and bought a cable that had the right barrels on each end and took it to a shop that cut it down to the right length. They were supposed to change the gray cable cover to black but didn't.I was in such a hurry to ride that I installed it and planned to have another made in the winter.....(Hey....its winter!!!!). Thanks for reminding me!!!!! ;D.........Hope you like the controls....I sure do!!!
Glad you didn't like the chrome fairing....I didn't either!!!!
Any other questions about the controls and such.....just ask.
MEMBER # 257
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #455 on: December 11, 2008, 11:06:58 PM »
Yeah, I've been farting around with them ::)
So you used the Yam cable, and just cut it to length? Both ends worked out in the control and Carb?
Or did you use the Yam cable with a honda carb end?
Having not seen a Yamaha cable I don't really know what to expect?
Offline mrbreeze
  • Not your average
« Reply #456 on: December 11, 2008, 11:37:32 PM »
Its been awhile but now that you mention it....I think I matched the upper barrel to the throttle and used the stock Honda at the carbs.
I think you just need to look at what you got and what you need and get a cable made.
Now that I really think about it.......I should look at my bike directly and tell you exactly what I did. We are using common parts and that does not mean they are compatable with other different items. I will try to get out to my bike this weekend in the daylight and verify a few things.
MEMBER # 257
« Reply #457 on: December 11, 2008, 11:53:35 PM »
Yes the pipes are quite attractive!
IIRC, the original Yosh pipe did not allow for filter or drainplug removal. The pipe had to be removed. Looks like the Yamiya? version makes those concesions.
The original also did not allow for the centerstand, can't tell about these pipes.
Same here Ron, my original Yoshi chrome pipe doesn't have the "tweaked" headers like Derek's replica, and I got it because the owner didn't like not having the use of his center stand. On the other hand, for the 50 bucks I paid for it, I don't mind at all..................  ;D
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #458 on: December 12, 2008, 12:32:30 AM »
Remember I'm an "Island Boy"
 I can't just drive down the road to the dealer..........It will be a complete day trip for me, so any advice / direction will always be appreciated.  ;D 8) I want to sort this before I even start with the electrics.
Offline mrbreeze
  • Not your average
« Reply #459 on: December 13, 2008, 11:41:20 AM »
OK Derek.....I found the wrapper label from the cable. It is a Motion Pro part # 05-0301.It has the correct ends but will need to be shortened.Also ...it has a gray colored housing so you may want to have that changed to black or whatever. The handle end does not screw into the control like the Honda cable.It just pushes into the hole and there is a tab that screws into the control that holds the cable in place.You should be able to get this tab & screw from a Yamaha dealer or Mike's XS has them.
MEMBER # 257
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #460 on: December 13, 2008, 06:01:55 PM »
Thanks. No response from me as I ponder what you said :-\
Offline mrbreeze
  • Not your average
« Reply #461 on: December 13, 2008, 07:12:11 PM »
Well........OK!!!!.....you ponder!!!!
MEMBER # 257
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #462 on: December 13, 2008, 08:01:49 PM »
So.....the carb end on the Motion Pro part # 05-0301 fits on our 750 carbs and I just need to snip shorten and sort?
Went to town today and stopped off at the Nanaimo Honda dealer and had a quick chat with my favorite mechanic. He suggested I go to the Yam dealer......(closed today?) and he was sure they could sort out a cable for me as they have made custom cables for the them in the past.
I think I may wait on the "online order just yet" and see what they can do for me.
Thanks very much for looking  ;D, I may still get back to your directions..........
Ponder over 8) ;D
Offline mrbreeze
  • Not your average
« Reply #463 on: December 13, 2008, 09:19:21 PM »
I'm trying to imagine how you look......sittin' out there in that nice new shop......just sittin' there pondrin'!!!!!!!!!!.....thats some funny sh!t. :D :D :D :D.....You'll get the cable worked out...I'm sure. I never said it was easy!!....(or did I ??)
MEMBER # 257
Offline fastbroshi
  • Puppet
« Reply #464 on: December 13, 2008, 09:50:26 PM »
  Looking at your new pipes, I could've sworn you were showing us a pic of your new CBX.
Just call me Timmaaaaay!!!
« Reply #465 on: December 15, 2008, 01:58:31 PM »
hahaha good one  ;D ;D
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #466 on: December 15, 2008, 05:22:09 PM »
Nothing much important in my pondering moments as you can see ;D
fuzzybutt
« Reply #467 on: December 15, 2008, 05:34:47 PM »
i didnt see if you said anything about the quality of those pipes or not Derek, whats it like? i want to buy the black one in the spring.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #468 on: December 15, 2008, 05:45:42 PM »
1st:  I have removed my center stand gear on this bike. So I don't know if that becomes an issue on a stock set up.
It fit perfect, did not interfear with rear sets or aftermarket oil filter adapter.
It weighs "nothing" ;D ;D
Very happy with the quality/
fuzzybutt
« Reply #469 on: December 15, 2008, 05:50:52 PM »
hopefully it'll fit with my centerstand. thats one of the 2 reasons i didnt get the dr gas xs pipe.
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #470 on: December 17, 2008, 10:39:32 PM »
Yamaha Dealer in Nanaimo......."Might just as well close their doors"
What a waste of store front :P
No go on a local source for throttle cable. I'll have a chat with Motion Pro about a custom.
http://www.motionpro.com/custom/index.php
« Reply #471 on: December 18, 2008, 05:45:01 AM »
great source, thanks!
fuzzybutt
« Reply #472 on: February 17, 2009, 11:14:27 PM »
so, hows it coming along derek?
« Reply #473 on: February 18, 2009, 10:36:21 AM »
the peanut gallery is getting restless, your running out of exccuses derek.  you better throw us a bone, before there's a revolt , and we storm the island, throw you in the mancave, and chain you to the tracy till it's done
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #474 on: February 18, 2009, 10:54:30 AM »
I've been trimming and shaving the fairing to get what I want as well as trying to get some wiring done.
Being color blind makes the last bit quite frustrating :P
I'll hit it a bit harder when we get back from our trip.
