Author Topic: CB400F steering lock  (Read 1327 times)
Offline mwrufforth
« on: July 08, 2019, 06:31:22 AM »
Just bought a 1975 CB400F, and it came without a steering lock key.
Can anyone advise where I might get a key. I can't see the lock number but I read somewhere that there are only 7 variations of the key.
I can buy  a new lock etc but if I fit one  then I first have to remove the rivet to remove the old lock, and I am not sure how to do this without damaging the splines.
Offline carnivorous chicken
Re: CB400F steering lock
« Reply #1 on: July 08, 2019, 04:44:42 PM »
The key should be the same as the ignition (and the seat lock), unless someone has changed it (which is suspect is why you're asking...). I don't know if the tumbler has a number on it -- someone else might come along and chime in.
Edit: Was thinking of 350F with the steering lock below the triple tree -- on the 75 400F, it's the same as the ignition switch. All you've got to do is turn your bars all the way to the left or right and a turn of the ignition key will lock them.
« Last Edit: July 08, 2019, 05:06:39 PM by carnivorous chicken »
