Author Topic: 73 CB500F leaky puck/head gaskets  (Read 1150 times)
Honda3
« on: July 15, 2019, 02:18:51 PM »
So there is a lot of opinion on what gaskets to use to fix this problem. Bike has 24k miles on it and the head gasket is leaking terribly, so much i dont ride it anymore (I have other bikes).
What is the BEST head gasket set to buy, and where from, that includes the much talked about "pucks?"
Thanks!!
Offline jaytee-nz
Re: 73 CB500F leaky puck/head gaskets
« Reply #1 on: July 15, 2019, 03:00:41 PM »
Always genuine Honda for me (although I'm sure there are other good quality gaskets out there but I don't think it's worth the risk). Here's a set on Ebay -
https://www.ebay.com/itm/NOS-Genuine-Honda-Top-End-Gasket-Kit-CB500-1971-1972-1973-06111-323-315/372460052435?fits=Model%3ACB500%7CSubmodel%3AFour%7CMake%3AHonda&hash=item56b8595fd3:g:Rk4AAOSw38Vbt7Il
Pucks aren't so much of a problem on the CB500 but the head gasket is.
« Reply #2 on: July 15, 2019, 04:00:25 PM »
Pucks are just as much a problem on 500 but also the O rings on the oil feed and the soft washer between the end cap bracket and cam cover.
Honda3
« Reply #3 on: July 15, 2019, 04:03:40 PM »
Thanks. But I recall being told, what a lot of ppl believe is a head gasket problem is actually a puck leak and that they are an issue. I was directed to get a head gasket set WITH the pucks included.
FOUND THEM: https://www.partzilla.com/product/honda/91318-300-013 and https://www.z1enterprises.com/cylinder-head-rubber-seal-cb750-cb650-cb550-cb500.html
And here is the thread:  http://forums.sohc4.net/index.php?topic=156764.0
And @ bryanJ, im going to swap all the gaskets.
Question, would a leaky head gasket reduce horsepower?
« Last Edit: July 15, 2019, 04:05:35 PM by Honda3 »
Offline Scott S
« Reply #4 on: July 15, 2019, 04:22:04 PM »
 Lots of good information in that thread.
 Read this one, too:
http://forums.sohc4.net/index.php?topic=107040.0
 Genuine Honda head gasket. Pucks and O-rings are available at 4into1.com,  too. You could probably get everything from them, even the sealant.
 Use the sealant sparingly.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #5 on: July 15, 2019, 11:58:47 PM »
NEVER EVER  use sealant on a genuine Honda head gasket and no a head gasket leaking oil will not reduce horsepower until you loose all the oil and sieze the engine, which is unlikely unless the leak is literally pouring out
Offline Deltarider
« Reply #6 on: July 16, 2019, 03:16:18 AM »
On the 500/550 leakage is often from the two O-rings at each side of the engine (oil passages). I once heard a mechanic who used Kawasaki O-rings that were just a little bit thicker. I forgot to take notes which ones they were. One could also consider a solution as in: http://www.cbfourclub.de/cbfourum/viewtopic.php?f=3&t=5083#p31455
Pardon my German, but I think the pic says it all. Personally I have no experience with this.
CB500K2-ED Excel black
Offline Scott S
« Reply #7 on: July 16, 2019, 03:58:54 AM »
 Yeah, I was referring to sealant on the pucks, as shown in Branden's thread.
'71 CB500 K0
'81 Yamaha XS650
Offline 1976cb750f836
  • 76 cb750f, 836, 78 wheels
« Reply #8 on: July 16, 2019, 05:53:54 AM »
My pucks( I got some of the crap ones), benn seaping  since 836 kit, bout 12 years ago.
Not enough to wet the fins, just enough to attract dust. I may never fix it?
