Author Topic: CB400F transmission slipping  (Read 3349 times)
Offline minimo
  • 1977 CB550F 1975 CB400F 1959 Ducati 200 Americano
Re: CB400F transmission slipping
« Reply #50 on: July 29, 2019, 11:59:38 AM »
Here’s the gear bushing and the split:
Online rotortiller
« Reply #51 on: July 29, 2019, 02:45:37 PM »
Do not know the fit of your bushing but I'd clean the OD of it and the gear ID with acetone or MEK, then I'd use sleeve retainer from Permatex just in case. It's  substantial work to split cases so I don't like to #$%* around with #$%*.
Offline minimo
« Reply #52 on: August 05, 2019, 12:23:18 AM »
And just like that, 1st gear is back to working like it should. I whimped out on replacing the the low gear bushing - didn’t want to be the guinea pig trying something different. It would involve a little more research and if I was really gung-ho for it I’d have reached out to Honda to see what their opinion would be (about using the high-performance plastic bushing from Igus).
The issue with my 1st gear, to confirm was a combo of a heavily worn bushing and rounded corner edges on the countershaft gear dogs. Was able to score a good replacement on both of those gears. I even made sure to install the thrust washers too this time :-)
« Last Edit: August 05, 2019, 07:18:27 AM by minimo »
