Author Topic: Will other CB750 exhausts work on cb750a?  (Read 3628 times)
Offline redrider1940
« on: July 17, 2019, 09:32:05 AM »
Hello,
I'm new here and I bet this has been asked before but I couldn't find anything with a search. On my '77 the left side exhaust is rusted out and the previous owner did a hack job getting it back together. So I am either looking for a decent OEM replacement or I was wondering if exhausts from other 750s would work on my machine?
Re: Will other CB750 exhausts work on cb750a?
« Reply #1 on: July 19, 2019, 05:24:32 AM »
A couple of the guys in the performance section are racing A's. They could answer. I plan to try couple but haven't yet. My older projects demand attention right now.
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
« Reply #2 on: July 19, 2019, 01:33:36 PM »
On this forum, a number of people have chimed in on this topic.  I'm not able to do a forum search right now.
Also available are CB750A specific aftermarket pipes.
Generally, the deeper sump on the CB750A is a problem - not enough clearance for most pipes, as they "hug" the bottom of the engine quite closely, normally.
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
  • Moderator
« Reply #3 on: July 22, 2019, 07:41:21 AM »
Completed search this morning.
Old thread - not much help.
http://forums.sohc4.net/index.php/topic,27553.msg1781806.html#msg1781806
« Reply #4 on: July 23, 2019, 05:35:30 AM »
Thanks. I bet he doesn't still have that exhaust still available :)
Offline grcamna2
« Reply #5 on: July 24, 2019, 10:13:06 AM »
Redrider,
I'm Bill,the reddit member who recommended this forum to you.We will figure out a way to get you some better oem type exhaust.  ;)
75' CB400F/'bunch o' parts'
« Reply #6 on: July 27, 2019, 05:26:04 PM »
Cool thanks
Offline carnivorous chicken
« Reply #7 on: July 28, 2019, 09:19:23 AM »
If that's at me -- nope, they went pretty quickly...
Offline sammon287
« Reply #8 on: September 04, 2019, 11:20:47 AM »
Redrider,
Please share if you find something that works. My 76A has a one year only exhaust (4 into 1). The header is cosmetically bad and getting it re-chromed doesn't seem to be an option. I'll switch to the later 4 into 2 if I have to.
1976 CB750A
Offline vik351
  • Adelaide South Australia ...
« Reply #9 on: September 18, 2019, 07:09:36 AM »
do folk run without  baffles in these like i did with my K2 back in the 70’s ...,?
or they too loud ? 2 into one set up ?
havent got my bikes yet, next week prolly...
vik...
Offline dave the welder
  • dave the welder
« Reply #10 on: September 20, 2019, 10:58:46 AM »
don't remove baffles carb is already on lean side. pulling baffles will really lean it out and run like #$%*
don't buy it build it
Offline vik351
« Reply #11 on: September 21, 2019, 04:21:50 AM »
OK , will well leave alone, I notice alot of the exhaust pipes are nearly blue and seem to be gettin a bit on the hot side.
So from the bits I have read on here the 28 mm round tops are a good start, quench the thirst a bit and same for the asthma...???
vik...
  • dave the welder
« Reply #12 on: September 21, 2019, 06:06:18 AM »
you will love adding the round tops
Offline vik351
« Reply #13 on: September 21, 2019, 06:36:34 AM »
Would you happen to know what I should get then, as in what part numbers etc thanks ...???
Looking on evil bay and there is bugger all for a set of K something all in one piece...
I really should get to ride my bike first I spose, might have lost the plot and sihtmeself on it anyway  :-[
But some how I dont think so... ;D
vik...
  • dave the welder
« Reply #14 on: September 21, 2019, 05:46:43 PM »
read thru all the performance mods listed here. they will walk you thru everything you need to swap carbs
Offline sammon287
« Reply #15 on: December 18, 2019, 04:31:59 AM »
All I can find new are MAC 4-into-2 for 77-78 model years. Nothing for a '76A. I wonder how much modification it would take to fit a 4into1 from another model. A little hammer massage, or cutting and welding?
1976 CB750A
Offline tscott
« Reply #16 on: December 22, 2019, 08:14:59 PM »
Yeah, I've got holes on the inside of both of my mufflers but the headers all look good. I'm assuming just taking a hacksaw to where the weld is holding the muffler to the headers (4-2 oem system) and then adding new mufflers with a clamp would not be a big deal... anyone on this thread done anything like that?
Thanks!
Toran
