Author Topic: Joining cases question  (Read 383 times)
Offline Scott
  • 72 CB750
« on: July 17, 2019, 01:18:52 PM »
G’day
When joining cases on a CB750 is Honda bond put thinly on all mating surfaces except the 3 internal crank bearing surface.
I would love to hear how you do it.
Cheers
Scott
Offline Bodi
Re: Joining cases question
« Reply #1 on: July 17, 2019, 01:56:35 PM »
You can run a thin bead along the case edges, detouring inside any bolt holes but I don't think there are any. A very thin bead, I don't have a measurement but maybe the size of a normal pencil lead. Three Bond won't cause the problems silicon can if it squeezes blobs inside but I try to use as little as possible to avoid them. Clamping the cases together will spread the bead, you don't have to try to cover the mating faces. Add a small blob by each oil seal so it will spread around the seal rubber for no oil dribbles.
Personally, I put a bead circle around the 8mm bolt holes on the mating faces by the crank.
Offline my name is nobody
  • I like Pontiacs and Hondas
« Reply #2 on: July 17, 2019, 04:48:48 PM »
Along the same subject, any easier way to get the lower case positioned/mated to the upper? Cumbersome...
I'm worried I bent the shift fork, although the case halves did meet squarely and completely.
I used Honda bond that the car dealer uses. A little bead will spread a lot when compressed.
I'm guessin the main caps need it to stop oil from leaking around the bolt heads outside the engine (?)
