Author Topic: moon shot  (Read 1486 times)
moon shot
« on: July 18, 2019, 01:24:02 AM »
well in honour of those brave men who years ago pioneered space flight in dodgy craft more or less a controlled bomb explosion heres a lunar module bbq im making from an old gas bottle.
Offline jgger
Re: moon shot
« Reply #1 on: July 18, 2019, 05:22:58 AM »
How in the hell did you cut it without blowing up?
Offline jaytee-nz
Re: moon shot
« Reply #2 on: July 18, 2019, 01:06:32 PM »
Nice Dave - NASA will be calling you shortly !
Re: moon shot
« Reply #3 on: July 18, 2019, 01:16:32 PM »
  Reverse engineering - what once powered a grill now becomes the grill !
Re: moon shot
« Reply #4 on: July 18, 2019, 02:16:50 PM »
it had no gas in it for ages with the valve removed,imagine cutting one full youd be the next man on the moon!
Offline jgger
Re: moon shot
« Reply #5 on: July 18, 2019, 03:14:44 PM »
I just wonder if cutting one with the valve removed would be an issue. I wouldn't want to be like the bomb tester guy in cartoons with a hammer!
Re: moon shot
« Reply #6 on: July 18, 2019, 03:33:05 PM »
Mix up some CO2 gas and fill the cylinder with that before cutting. The CO2 is heavy and will sink displacing the propane.
Re: moon shot
« Reply #7 on: July 19, 2019, 01:41:46 AM »
this bottle sat for near a month with no valve and upside down,the lpg is heavier than air and would be long gone,ive cut em before,just pull the valve and fill with water itll displace any gas,even if a little remained with the valve missing and a slot cut it might do half a fart if that but it aint gonna explode!im sure throwing a full one on a big ole fire would be spectacular?first burn today blistered all the paint off,ill heat black paint it tomorrow,poor bear thought we were going to cook some meat.
« Last Edit: July 19, 2019, 01:43:51 AM by dave500 »
Re: moon shot
« Reply #8 on: July 20, 2019, 01:39:21 AM »
some heat paint for re entry protection!
« Last Edit: July 20, 2019, 01:45:08 AM by dave500 »
Offline Bodi
Re: moon shot
« Reply #9 on: August 03, 2019, 12:37:48 PM »
"throwing a full one on a big ole fire would be spectacular"
Tried it. They have a burst disk overpressure relief in the valve unit so I got a wicked flame shooting out - for quite a while - but no explosion. Maybe a bigger/hotter fire would get one to pop but one test was enough for me.
Re: moon shot
« Reply #10 on: August 03, 2019, 02:31:43 PM »
Nice grill Dave!  How's the 'roo steaks turn out?!
What's next, Camel sausage?!
Re: moon shot
« Reply #11 on: August 03, 2019, 07:13:44 PM »
Looks great Dave, well done. Many years ago when I was still in the regular army I blew up a full 9Kg gas bottle with a slab of plastic explosive, right on dusk. It was a spectacular event! ;D
Re: moon shot
« Reply #12 on: August 04, 2019, 12:37:53 AM »
trust you terry!how bout sitting one in a fire then hitting it with a good old .303?looks like a job for myth busters?ill bet only a jet of flame will come out,try an acetalyene bottle?ya can sit around these quite cosy once done cooking,load her up with wood goes for hours.
those legs were some sort of steam pipe off cuts I saved from a dumpster,Bear gets that look when theres food around!
« Last Edit: August 04, 2019, 01:14:45 AM by dave500 »
Re: moon shot
« Reply #13 on: August 04, 2019, 01:11:56 AM »
Smores anyone?
Re: moon shot
« Reply #14 on: August 04, 2019, 01:29:27 AM »
heres the top I took of it,might cut that ring off and make a sort of wok out of it?
Re: moon shot
« Reply #15 on: August 04, 2019, 03:24:01 AM »
Ha ha, it was better than just that Dave, I was blowing up an unexploded 84mm Carl Gustav High Explosive Anti Tank round and some 40mm grenades, and the gas bottle was one an old guy dropped off at the servo I worked at part time, that was past it's use by date, so the explosion and ensuing light show was magnificent.
The good thing with HE is you don't have a little hole like a .303 going thru the cylinder, but rather, the cylinder pretty much disintegrates and you just have a huge plume of gas expanding at 27 times it's volume, so the flame front is very pretty. ;D
Re: moon shot
« Reply #16 on: August 04, 2019, 08:02:40 AM »
  I welded an outlet pipe on a large train car size map gas tank. It was open for weeks and I had finished the root weld, in the morning I noticed an 1/8" gap that I had missed, I cranked up the amps and decided to burn it in and then grind it smooth. When the arc got to the gap there was a large WHANG sound. Apparently a bit of gas settled in the low spot and the sound was the check valve blowing open and slamming closed. When I looked back, I was in the road and there was a trail of welding gear behind me. I felt rather silly because running would not have helped, that was almost my moon shot.
  Later, my boss was bidding a revision to the piping and I told him remember, when I strike the first arc he would be standing right beside me. He designed it to be a bolt on job with several flange unions.
« Last Edit: August 04, 2019, 08:08:08 AM by Don R »
