Author Topic: wideband O2 working! or is it? it is!  (Read 4858 times)
« on: July 19, 2019, 09:50:11 AM »
 I finally found some time to make a test fixture, I've seen a few online and believe this one will work. It's similar to some seen here. I'm using an auto meter pro plus wide band sensor it operates a gauge and can data log also if want to spend the time and $$ for a small logger. I saw a diagram that showed how to make one at home. I'm not sure I'm up to that but want to get this running at least so I can watch the gauge while riding. Will be near the tach. And not near traffic so nobody have a cow.
 This will work on the two 4-4 bikes, drag bike and hopefully the gl1000 stock pipes.
« Last Edit: September 22, 2019, 01:58:39 PM by Don R »
Re: wideband O2
« Reply #1 on: July 19, 2019, 10:00:26 AM »
 Upon review of the instructions ( I know that's cheating) the gauge needs to see 13.5 Volts (so it knows the engine is running) to activate the sensor heater which draws one amp. I'm assuming the best place to read that is direct to the hot side of the battery. I planned to use the charger pigtail for a quick connect.  pics soon.
Re: wideband O2
« Reply #2 on: July 19, 2019, 03:52:27 PM »
  I drilled a stock baffle so the probe goes in past the interior baffle. Hopefully not much restriction inside.
https://photos.app.goo.gl/kVwQ3YNJdbaZcZ5FA
« Last Edit: July 19, 2019, 08:01:58 PM by Don R »
Re: wideband O2
« Reply #3 on: July 19, 2019, 07:59:02 PM »
https://photos.app.goo.gl/qESTbuR6XC5a3T2c7  With the petcock off.
https://photos.app.goo.gl/57EHyQvvgRkLBtNb7   Fuel on, engine cold no choke.
 Sorry for the links, everyone can't see my posted pics. The toggle switch is for a wide open run to save the maximum lean reading for playback. Two wires may be connected to a laptop, two others are for a data recorder. I'd love to find a used cheap Auto Meter data recorder.
« Last Edit: July 19, 2019, 08:05:16 PM by Don R »
Re: wideband O2
« Reply #4 on: July 19, 2019, 08:04:12 PM »
Guessing that your test fixture did not involve tapping a bung into those 4 into 4s
Re: wideband O2
« Reply #5 on: July 19, 2019, 08:05:49 PM »
Tailpipe probe into the interior chamber. And you guessed right. The gauge plugs into my battery tender connector and one bolt moves it to other handlebars. I'll use a small hose clamp inside the exhaust baffle to keep it from falling out. On other bikes, I'll fab something else. Can't wait to take it for a ride on a little used blacktop and do all 4 pipes. This cyl. previously glazed a plug, it had an exhaust leak at the copper gasket and some carb issues.
 This fixture is just mig tacked, if it works, I'll grind the tacks and tig it.
« Last Edit: July 19, 2019, 08:13:18 PM by Don R »
Re: wideband O2 working!
« Reply #6 on: July 19, 2019, 09:36:55 PM »
My hand bent yoshimura pipe has always had a tapped bung in the end, and I wonder what it was there for back in the 70s or 80s
« Reply #7 on: July 19, 2019, 10:19:55 PM »
 Good question. I have a pyrometer too but won't drill pipes to install it. I doubt it would be much use in the back. I can't wait to but this on a bike with Webers and a 4-1 V&H on it.
« Reply #8 on: July 19, 2019, 11:57:30 PM »
Really handy gauge that show the ratio both with numbers and quick look by LEDs that can alarm when way too wrong.
Possible to ride bike with the sniffer mounted?
The Dyno guy that measured A/F ratio on my K6 sticked a long pipe into the exhaust to measure as close to the ex port as possible. Compressed air sucked the gases out thru the pipe on outside where the  sensor sat.
The sniffer that Daytona Wego 3 has as example is attached on ex pipe's end.
I think it will work if making a run on the Dyno with the pros tooling,  run similar run on the road and compare the values and make a reference formula.
I have a Daytona Wego 3 I have not hooked up yet. The Hindle 4-2-1 has a wide hole perfect for a deep sniffer device.
« Last Edit: July 19, 2019, 11:59:19 PM by PeWe »
« Reply #9 on: July 20, 2019, 05:57:09 AM »
 Yes it should work out while riding. The probe goes into the inner exhaust chamber of the muffler, it might need to be longer for headers. The efi on my dragster is really finiky what pipe I put the sensor on, my headers are slip ons and leak air at the merge. I got a sensor too close to the end and it ran awful. 1 or 2 seem to be the best primary pipes on the V8.
Offline gschuld
« Reply #10 on: July 20, 2019, 09:01:02 AM »
I’ve installed a weld in threaded bung just past the collector for a Wego 3 on a machine bent Yoshimura copy pipe.  It’s positioned there so it will fit inside the right fitting belly pan and out of the way for data logging.
George
« Last Edit: July 20, 2019, 09:05:35 AM by gschuld »
« Reply #11 on: July 21, 2019, 10:18:46 PM »
That's my plan for the big motor with the V&H.
« Reply #12 on: July 23, 2019, 09:02:54 AM »
 I got in a short ride this morning, at part throttle cruise, 3 to 4 thousand rpm it reads around 10-1. At idle, it  goes way lean, I suspect it's getting some outside air. It has the early 4 cable carbs, 120 mains and stock pilot jets, 30 or 35? I'm interested to see what wide open throttle reads, that may tell me if it wants smaller jets or lowered metering rods.
 This is all on #1 so far. It works great, it lights when plugged in, starts warming the o2 when it sees 13.5V and when the o2 sensor is heated it starts reading. It might be more fun with key on starting but it's a temp deal so,,,
« Reply #13 on: July 27, 2019, 03:28:48 PM »
 It reads way rich at any cruise speed looks better while accelerating. I'm wondering if the probe is causing a flow problem where it passes through the interior baffle? I'll try shortening it up and make some mods.
Offline Kevin D
  • SE Michigan
« Reply #14 on: July 27, 2019, 05:03:48 PM »
Stock low speed jet for K0/K1 is 40
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
« Reply #15 on: July 27, 2019, 05:12:32 PM »
Yeah.......I have been there.
« Reply #16 on: July 27, 2019, 06:57:09 PM »
 When I'm accelerating it's 12.8-1 to 14-1, as soon as it's cruising, 10-1 I suspect it's lower but that's as far as the scale goes.
Offline MessnerMoto
Re: wideband O2 working! or is it?
« Reply #17 on: July 29, 2019, 01:51:07 AM »
I like this, probably better to tune it like this then on dyno table if you want to drive a bike
do you have links for the parts ?
Offline CBJoe
« Reply #18 on: July 30, 2019, 03:48:12 AM »
I think it's just one of these kits? https://www.amazon.com/Daytona-Twin-Tec-Metering-WEGO3SYS/dp/B000WK5JXG
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
« Reply #19 on: July 30, 2019, 04:11:03 AM »
Info about the values to go for when measure and when.
http://www.afrplus.com/AFRplus-unit-functionality.asp
« Reply #20 on: July 30, 2019, 09:04:39 AM »
 I got this with contingency winnings from racing. https://www.autometer.com/2-1-16-wideband-pro-plus-w-sensor-sport-comp.html
 I'm doing some volunteer work on a friends dune buggy and need it out of my shop soon. I'll find some time to change the probe and report back.
« Last Edit: July 30, 2019, 09:06:28 AM by Don R »
Offline dugsgms
« Reply #21 on: August 02, 2019, 10:05:55 PM »
10:1 is pretty rich for cruise and 12-14:1 under load is pretty lean for a these engines. When I did mine I was seeing about 1 to 2 points richer than what you'd want to see in a air cooled engine if you were looking for max power pretty much everywhere(e.g. 11:1 under heavy load and 13:1 during cruise).  I wonder if the 4 into 4 exhaust is causing problems with the readings due to the somewhat infrequent exhaust pulses in each pipe(reversion?).
Also, be careful going after the ideal a/f readings given on the internet. They aren't ideal for a street ridden air cooled engine, especially one equipped with carbs that lack accelerator pumps.
1970 BSA Lightning
1975 Yamaha RD350
1975 Honda CB400f
2008 Yamaha WR250R
« Reply #22 on: August 03, 2019, 08:43:27 AM »
I had a WEGO on my 750 for quite a while. I had ....what I felt....the RS-34's pretty dialed in. Went to the dyno and ended up going down 3 main jet sizes. The idle A/F was very good. My point is the meter can get you close....especially the idle. The dyno will tell the real story. ;)
« Reply #23 on: August 03, 2019, 09:43:55 AM »
 I took on a free VW project for a lady in our car club that deserves some automotive help. It's almost done (hopefully) and I can spend some time on the meter again.
  It would be fun to have it working when the webers and V&H header are on a bike. I don't think the readings are correct yet, especially in cruise. The probe may be causing some backpressure issues.  The V&H collector will get a welded bung, I bolted the 4 hole back plate of an old gauge in the V&H for the appearance of a baffle. That may also reduce outside air reversion a little.
« Reply #24 on: August 24, 2019, 11:16:37 PM »
 I took a ride with the o2 in place and tried the other 3 cylinders. It looks lean at idle but am guessing that's air contamination. At most rpm's the meter read on the safe side, 12.8 to 13.8. I do have the baffles out right now. Next time I'll replace the baffles, retest and set up a course where I can repeat rpm's and gears, stop and make notes on each cylinder. I'd like to see a WOT test at 6K or so too.
 My toggle needs to be replaced with a push button to record the high (lean) number of each run.
