Author Topic: Leak from Tach Cable K2 750  (Read 614 times)
Honda3
« on: July 25, 2019, 05:55:25 AM »
Put the new Yamiya kit on my bike yesterday. Over the past week I had been smelling burning oil. I checked around where the tach cable goes into the head and saw it leaking very slowly.
What is the cure for this?
Offline BenelliSEI
  • 1969 cb750
Re: Leak from Tach Cable K2 750
« Reply #1 on: July 25, 2019, 06:03:18 AM »
There’s a small seal in the cam cover, under the cable. Search ‘tach seal” on this forum for lots of info.
Honda3
« Reply #2 on: July 25, 2019, 06:09:05 AM »
is it hard to replace?
Honda3
« Reply #3 on: July 25, 2019, 06:22:02 AM »
I just found a great video on this for anyone else who might search the topic
« Reply #4 on: July 25, 2019, 06:37:27 PM »
I pull them out with a crochet hook (whole set of them $3 at Joann Fabric stores). You can buy individual seals from CB750Supply.
« Reply #5 on: July 26, 2019, 03:35:54 AM »
Honda still stocks those seals also,less then 5 bucks.
« Reply #6 on: July 26, 2019, 03:48:06 AM »
Do not press too hard with a small screw driver, the valve cover is very thin under that seal and can crack, pieces to fall inside cam holder. I know...
Quick fix when I knew a guy that had valve covers and my bike has Franks frame kit. Garage time instead of relaxing TV that evening. No frame kit..what a waste of time!
Honda3
« Reply #7 on: July 26, 2019, 08:05:43 AM »
And what do you use to push the new one in?
« Reply #8 on: July 26, 2019, 09:52:37 AM »
Push it in and then gently seat it by tapping a socket slightly smaller then the cable fit hole to gently seat it.Little thin film of grease around the outside of seal won't hurt.
Honda3
« Reply #9 on: July 26, 2019, 10:23:35 AM »
thanks for this!
