Author Topic: All Balls steering head spacers??  (Read 534 times)
Offline Hotwheelbill
« on: July 25, 2019, 12:31:16 PM »
I just got my Amazon All-Balls 201011 steering head bearing kit. 1976 CB750. It has two spacers. Can anyone tell me if I need the thinner or thicker one? Or is there a measurement I need to take?
I love to make my bikes worthless due to high mileage!
2004 ST1300A .... the fast one. And dragging pegs on a CT.
1972…parts bike
1974…. Rusty frame but runs
1974 CB750..... Powder coated frame and parts, waiting for $$ hot rod motor.
1972 with 1975 old school drag motor
Offline Gene
  • Chat enuf you too can be a
Re: All Balls steering head spacers??
« Reply #1 on: July 25, 2019, 12:36:40 PM »
There is a measurement - I don't recall it but I know it's in the instructions.
Do a search on the site here - typically it's the thinner one.
*1973 CB750K3 (Bow)
Offline Gene
*1973 CB750K3 (Bow)
« Reply #3 on: July 25, 2019, 01:03:30 PM »
Thanks guys. That was just what I needed including to tip of using the other spacer to help drive it home!
1972…parts bike
Offline pjlogue
« Reply #4 on: July 25, 2019, 04:21:01 PM »
You may have an issue with the top bridge sitting higher than where it did with the old bearings.  The headlamp "ears" may have a gap between the top of the ears and the upper top bridge.  I had this problem on my '76 750K and '76 GL 1000.  I ended up using the old upper bearings and the new tapered bearings on the lower.  The top tapered bearing is thicker than the old ball bearing.  I believe I used the thinner washer for both bikes.
-P.
Offline Mr.Mazza
  • The man from down under
« Reply #5 on: July 26, 2019, 06:39:49 AM »
-P.
I ended up with this same issue but only by 1mm, the ears still held fine and no other issues
Driving a car is watching a movie, riding a motorcycle is starring in the movie
« Reply #6 on: July 26, 2019, 11:40:11 AM »
I guess that I should have mentioned that this is a 1976 GL1000 front end......ooops!
1972…parts bike
