Author Topic: Cb 550 gearbox can’t push it up  (Read 708 times)
Offline olasek18_18@o2.pl
« on: August 04, 2019, 11:33:03 AM »
I have a problem with my Cb 550,
I have only first gear and neutral, can’t push it up.
 Before Gear box worked well, It!s happend when I start up my bike. Last ride was normal...
Any suggestions? Please help
Thank You
Re: Cb 550 gearbox can’t push it up
« Reply #1 on: August 04, 2019, 01:16:07 PM »
Are you trying to change up when stationary? If so this rarely works well as both gearbox shafts need to be rotating to get gears easily.
« Reply #2 on: August 04, 2019, 02:20:47 PM »
I try rotary, I ride a little speed on 1 gear, I can push only on neutral and can’t go up
Online jgger
« Reply #3 on: August 04, 2019, 03:45:12 PM »
Did the bike fall or tip over? Another member had a similar problem and it turned out to be a bent shifter.
« Reply #4 on: August 05, 2019, 01:17:33 AM »
Bike didn't fall, but first think what I''ll do is check springs and bend shifter... I don't want to believe it's gearbox
