Author Topic: Question - 1972 Honda SL350  (Read 2768 times)
Offline The_Rooster
« on: August 11, 2019, 04:36:46 AM »
I just picked up this bike as a project and am still trying to decide what to do with it, classic or cafe... Anyway my question is that this bike has a stripped shift spindle. I know the carbs are different but will a CB350 shift spindle work in this bike? I am hoping they are the same. I hope someone here will be able to answer my question and if there are any other major differences clue me in.
Thank you!!
Re: Question - 1972 Honda SL350
« Reply #1 on: August 11, 2019, 05:54:33 AM »
  Don't know the spindle answer but did the bike come with good original exhaust pipes. If so the would be a major bonus.  I had one of those back in the 80's for awhile,always liked the looks of them.
Offline WhyNot2
  • I'm finally an
« Reply #2 on: August 11, 2019, 06:47:48 AM »
How stripped is it?
Can you post a picture?
I really think a CB or a CL will work. I used a CL in my CB.
Offline lafindufondu
« Reply #3 on: August 11, 2019, 08:06:57 AM »
Pretty sure the bottom end is the same across cb, cl and sl
« Reply #4 on: August 11, 2019, 09:35:15 AM »
Check using the parts fiche at places like South Sound Honda. That will tell you if Honda swapped them.
Offline dhall57
« Reply #5 on: August 11, 2019, 09:37:10 AM »
This was the OE spindle #24610-286-030 for CB, SL, CL 350 models
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
« Reply #6 on: August 11, 2019, 08:17:30 PM »
The clutch or primary is different from the others on the 2 years of double down tube frames, so make sure the shifter will fit.
 And let me know if you have spare primary stuff.
Offline low-side
« Reply #7 on: August 14, 2019, 11:41:12 AM »
If it's complete and in decent shape I'd keep it original.  Not that many of them made, and a lot of them got thrashed.  Stock mufflers are practically unobtanium, so if yours came with good mufflers you are very lucky.  I agree with Hondaman, check the fische to be sure about the shift shaft.
Offline the-chauffeur
« Reply #8 on: August 20, 2019, 08:39:46 AM »
If anyone's still interested, this question has been answered on the HondaTwins forum.  Essentially, the K2 arm is slightly different to the K0 arm - something to do with the K2 not having a starter motor.
As far as exhausts are concerned, pretty much exact K1/K2 replicas are available, although they're not exactly cheap.  The really tough ones are the K0's, along with the chromed cover plates . . .
« Last Edit: August 21, 2019, 06:50:07 AM by the-chauffeur »
Offline WhyNot2
  • I'm finally an
« Reply #9 on: August 20, 2019, 08:53:04 AM »
Cool, glad to hear info was available.
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #10 on: December 04, 2019, 07:03:38 PM »
     I know that this topic is pretty old. But, thought I'd post a photo of my SL350K2, that's not completely stock (especially the
     exhaust), but it's mine & I'm proud to have it. That's what matters. So, I'm posting here, to see if there will be any others who
     might have input, on the SL350s.
Member # 1969
Offline WhyNot2
  • I'm finally an
« Reply #11 on: December 05, 2019, 05:03:41 AM »
I too have one......in process:
Offline bill440cars
« Reply #12 on: December 05, 2019, 05:10:48 AM »
           Nice to know there are still a few being worked on. Always good to see another one getting attention.  ;)
Member # 1969
Offline bill440cars
« Reply #13 on: December 05, 2019, 05:27:42 AM »
           The previous owner came up with a black low mounted 2 into 1 system and put it on there.
           It is in great shape, but being a low pipe on this sort of motorcycle, doesn't make any sense. And the way the pipe is
           routed, the side stand mount was bent outward slightly, by the previous owner and this causes the SL to lean over
           more, when parked on the stand. SO, I am working on putting a CL exhaust on it, except it will be completely
           blackened & might be using short reverse cone megaphones on it.
           Currently, the clutch is stuck. And I have tried to break it loose, but it just doesn't wan to give. So, I will be going into it
           and take care of it.
Member # 1969
Offline WhyNot2
  • I'm finally an
« Reply #14 on: December 05, 2019, 05:58:30 AM »
I wonder, did the op get theirs going.
I'd like to see some pics of the op's bike and your Bill.
Like to see that exhaust work, as I'm going to go through the same.
Thanks
Offline bill440cars
« Reply #15 on: December 05, 2019, 09:36:27 AM »
Thanks
          I am working  on getting a photo posted. I thought I have it on my PC, but couldn't find it. So, I transferred it from my
     cellphone and it was supposedly accomplished, but I still haven't found where it went. I hope you'll bear with me, I'm
     sometimes, kinda hit & miss with my P/C & doesn't help that I am using an I Phone & STILL learning on it, as best as my
     old brain will allow.
          Mine runs, but I need to take care of the stuck clutch, getting an exhaust set up, like I want & then I will be setting it up
     with lights. I have the headlight & mount pieces. I also have the tail light mount bracket, BUT, the tail light is toast. I DO
     however, have an extra CB77 Tail Light & a Lucas Style Tail Light. I just have to decide which one to use. Kinda leaning
     toward the Lucas Style (like the older British motorcycles (BSA, Triumph, Royal Enfiled & such used. That way, I would have
     the CB77 tail light, in case I do another CB77 build. I'll work on getting photo(s) of my SL posted soon as I can.  ;)
Member # 1969
Offline bill440cars
« Reply #16 on: December 05, 2019, 10:03:57 AM »
     If this works, it isn't the best photo, but I will try to get a better one, to post up here.
     Oops, it's the same photo. Sorry about that. Trying to do several things at one time, doesn't work out to well, for me, apparently.
« Last Edit: December 05, 2019, 10:06:11 AM by bill440cars »
Member # 1969
Offline WhyNot2
  • I'm finally an
« Reply #17 on: December 05, 2019, 02:55:42 PM »
Looks like a 19" front wheel with the 21" forks, Bill..
I've got both setups.....19" and 21".
Thinking of doing a brat style build so will use 19" w/CB500 forks.....wish I could use the 21" with the CB500 forks, we'll see.
Offline bill440cars
« Reply #18 on: December 05, 2019, 06:32:24 PM »
   Well, actually, mine had the 21" front wheel. And, is that a CB500, derived front the 450 or the CB500 Four? Hope I am not asking a seemingly dumb question. I haven't even thought of doing any swapping around, in that area. But now that you have mentioned it, I just might give that some thought.
Member # 1969
Offline WhyNot2
  • I'm finally an
« Reply #19 on: December 07, 2019, 03:46:44 AM »
I have two sets of forks.
On the right are the cb550 forks, left are the sl350.
Offline bill440cars
« Reply #20 on: December 07, 2019, 06:34:54 AM »
     I have to ask, by using the CB550 forks, where will you go from there, as far as the axle & front wheel (500 axle & a rim laced up with a 500 hub?) I haven't done much switching around, of those parts. Myself, I have a complete front fork, from a Honda VT750, that I hope to use, someday, on something (But, of course, this would be on a street machine).
      I need to get some better photos of my SL, so the exhaust can be better seen. I have a home built exhaust, I bought off ebay, that is for a 450, that is a great design for a scrambler (off-road), but of course, it won't fit my SL350 (unless I tried to fit a 450 motor in the 350 frame and I wouldn't even be possible. I do have a place I could use THAT exhaust, BUT don't know if I will ever be able to get to that one or not. BUT, that's another story.  ;)
Member # 1969
Offline WhyNot2
  • I'm finally an
« Reply #21 on: December 08, 2019, 06:30:27 AM »
Bill, seems we took over his thread from the OP.
Sorry about the the threadjack The_Rooster.
I've got an original 19" wheel w/new tire, and an original 21" wheel from the SLs.
The 21" will only fit the longer forks, the 19" fits using the same axle for both wheels.
Took a few different tries to setup an axle for the 500 forks to the 19", I think a regular CB350 axle ended up being the one.
Course fitting different spacers was included into finding the right setup.
At least with the 500 forks, I now have an option of putting a front disk brake.
I have all parts needed, except the front wheel and disk.
So I'm in the market for that, just waiting for the right stuff to come up, at the right price.
Too much "get rich quick" stuff out there with too high of prices.
Patience....................
Offline bill440cars
« Reply #22 on: December 10, 2019, 08:12:59 AM »
    Oops, sure didn't intend to hijack. my apologies to The_Rooster as well.  ;)   I just kinda get carried away sometimes, on the subject of certain subjects.
Member # 1969
