Author Topic: 1977 Cb400f front forks help  (Read 1119 times)
Offline Can550
« on: August 15, 2019, 10:04:14 AM »
Removed both forks as seals were leaking. Stripped bottom Allen bolt (#14) of one fork so stuck there, other opened up but part #9 didn’t come out of fork.
Any thoughts of both issues please.
Thanks
Offline rupaulpierce
Re: 1977 Cb400f front forks help
« Reply #1 on: August 15, 2019, 11:11:52 AM »
Part 9 just gets hung up in there, should be able to poke/bang it out. It will fit through the upper fork seal.
Part 14... maybe reshape with a dremel attachment and use a larger hex wrench, or cut a slot and use a screwdriver? Either way soak it with penetrating oil and heat it up before you try again.
Offline Can550
« Reply #2 on: August 15, 2019, 11:17:31 AM »
#9 isn’t there
No where
« Reply #3 on: August 15, 2019, 11:21:24 AM »
#9 isn’t there
No where
In that case you need part #9 ;)
« Reply #4 on: August 15, 2019, 11:25:57 AM »
Are you 100% sure it’s not stuck in the bottom of the fork lower?
Offline jakec
« Reply #5 on: August 15, 2019, 11:30:04 AM »
#9 is what #14 screws into. So you only have one problem, that's nice ;)
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline jakec
« Reply #6 on: August 15, 2019, 11:31:31 AM »
I would fill the fork lower with PB blaster and leave for a while, then try your favorite extraction technique. Probably too recessed to get a chisel on it so maybe try an extractor. I recently used one on an exhaust stud and it worked great.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #7 on: August 15, 2019, 11:36:16 AM »
You sure 14 doesn’t thread into 5, sandwiching 9? I can’t remember. Anyway, I don’t know how the fork could function without 9.
« Last Edit: August 15, 2019, 11:38:36 AM by rupaulpierce »
Offline jakec
« Reply #8 on: August 15, 2019, 12:18:19 PM »
I think you are right.
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline Can550
« Reply #9 on: August 15, 2019, 12:25:45 PM »
I think I can confirm it’s missing. Now do I have to have it or bolt it up without it.
It seems like function it serves is to keep spring in center ?
Offline jakec
« Reply #10 on: August 15, 2019, 12:59:05 PM »
I'm sure they put it there for a reason!
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
« Reply #11 on: August 15, 2019, 01:06:48 PM »
I would not bolt up without it. You can get a whole fork leg for under $50. I’m sure someone on here has a spare #9.
« Reply #12 on: August 15, 2019, 02:22:31 PM »
Just drill into the hex head with a 6mm drill till the head comes off you then replace the bolt and sealing washer, common thing in workshops of the day!
Offline Can550
« Reply #13 on: August 15, 2019, 05:52:16 PM »
Got the Allen bolt out of the other fork and part #9 was there. Bike is sitting in a place/ spot that I got to move it. Not sure what to do
« Reply #14 on: August 15, 2019, 07:40:38 PM »
Any sohc4 (and probably lots more)is gonna have the same Allen screw.
« Reply #15 on: August 16, 2019, 10:07:00 AM »
He also needs #9!!!
« Reply #16 on: August 16, 2019, 10:09:04 AM »
Can, I would buy a donor fork tube and get both part #9 and a fresh Allen bolt for your existing forks.
« Reply #17 on: August 16, 2019, 10:10:14 AM »
« Reply #18 on: September 12, 2019, 06:24:52 AM »
Can, you get this sorted out?
Offline Can550
« Reply #19 on: September 12, 2019, 06:26:43 AM »
No
I had to bolt it up without that part in order to move the bike as it was sitting in the middle of garage.
Offline Alaxy Galaxy
« Reply #20 on: September 12, 2019, 07:28:35 AM »
You could aslo just get a pair of oil locks from England for fairly cheap.
https://www.ebay.ca/itm/202773492384
