Author Topic: CB400f carb float pin post broken  (Read 427 times)
Offline Jess72chev
« on: August 18, 2019, 08:52:31 am »
Hello all,
New to the group and have a question..
I have a set of CB400f carbs that have been sitting for 20 years.. During disassembly I got all but one of the float pins removed and ran into trouble.. I got pin halfway through and the top of the pin post broke..  Maybe this is a dumb question... is it fixable? Or just find another set?
Offline minimo
  • 1977 CB550F 1975 CB400F 1959 Ducati 200 Americano
Re: CB400f carb float pin post broken
« Reply #1 on: August 18, 2019, 09:05:40 am »
Sure, best is to find a replacement but yes, this can be fixed. Get in touch with Jim French.
http://www.jmfmicroweld.com/index.php
« Reply #2 on: August 18, 2019, 09:41:56 am »
+1 on Jim. Microwelding with a laser.
Offline Jess72chev
« Reply #3 on: August 18, 2019, 06:21:25 pm »
Thanks for the feedback!! So i May have found a replacement carb body. What about the throttle valve slide? Can I use the one from the old carb? Do I need to get a new one?
Thanks!
Offline minimo
« Reply #4 on: August 18, 2019, 06:34:59 pm »
Thanks!
You can use the old slide and all other parts as long as they’re in good condition. Good luck!
