Author Topic: Airbox  (Read 521 times)
Offline kakon864
Airbox
« on: August 20, 2019, 07:58:06 am »
Hello,
I am missing the airbox for my 77' cb550k and was wondering if I should try to acquire an original one or go with an aftermarket option? What are good aftermarket air filters?
1977 Honda CB550k
1978 Yamaha Dt250
1979 Yamaha XT500
1973 Kawasaki G5 100
Offline Bankerdanny
  • Endeavor to persevere
Re: Airbox
« Reply #1 on: August 20, 2019, 08:02:39 am »
I would recommend trying to find an original. They aren't that hard to come by as a lot of people remove them for café and brat bikes. Just make sure that you get a box for 77 or 78 550K, the boxes for the earlier K models and any F model won't fit because the 77-78 550K uses different carbs than all the other 550's.
It is possible that an earlier airbox setup will work if you replace the box-to-carb rubber with the correct ones for your year.
Re: Airbox
« Reply #2 on: August 20, 2019, 08:29:14 am »
This is what you will need to restore.  However, the 77 K model used a similar air horn over the filter box, as in the second pic, instead of the tray/cover shown in he first.
There aren't any aftermarket options that won't require rejetting the carbs.
Offline kakon864
Re: Airbox
« Reply #3 on: August 20, 2019, 08:36:55 am »
All I could find for complete air boxes is a 77' F model one for $100 on ebay, but looks like it would fit if I change the boots. I will also try asking in the wanted section of the forums.
1977 Honda CB550k
1978 Yamaha Dt250
1979 Yamaha XT500
Online bryanj
Re: Airbox
« Reply #4 on: August 20, 2019, 08:39:46 am »
No it wont.
Offline kakon864
Re: Airbox
« Reply #5 on: August 20, 2019, 09:03:06 am »
Hmm. Glad I asked.
1977 Honda CB550k
1978 Yamaha Dt250
1979 Yamaha XT500
Offline Scott S
Re: Airbox
« Reply #6 on: August 20, 2019, 09:35:03 am »
No it wont.
 Why not? The only difference is the carb to plenum boots. It should work just fine.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Johnie
Re: Airbox
« Reply #7 on: August 20, 2019, 12:58:39 pm »
List an ad in the "wanted" section of this board.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline CBDee
Re: Airbox
« Reply #8 on: August 20, 2019, 01:16:14 pm »
See Sohron's "cb550 assembly manual" in the maintenance section for more information.
Sent from my Old & Busted PC using Myindexfingers
