Author Topic: dyna-s on a cb650  (Read 3106 times)
sfcb
dyna-s on a cb650
« on: January 31, 2007, 09:20:00 PM »
hello all.  i recently discovered that my pulse generator is not functioning correctly, so i'm trying to fit a dyna-s (DS1-2) on my '79 cb650.  now dynatek doesn't make a unit for my model, so i got one that fits a 550 & 750.  the mounting plate is a little bit larger than stock, so i cut it down to fit.  now my question is the wiring, before i kill something.  the dyna has a 2 wires for each set of coils (1&4,2&3) and a red wire to go to ignition switched 12 volts.  now since this unit is for another bike, my wiring is a little different.  on my 4 pin connector which connects to the pulse unit, 2 wires are for one set of coils (yellow) and the other 2 are for the other set of coils(blue).  should i connect the dyna to this connection or straight to the coils?
sfcb
Re: dyna-s on a cb650
« Reply #1 on: February 01, 2007, 03:24:05 PM »
well for those who want to know, i called dynatek and this is what they told me.  they said to wire the unit staight to the coils and they are sending me a resistor to put on my coils to obtain the 3 ohms i need to run this safely.  i'll let you know how this works, in case anyone wants to run this system on their cb650.
Offline Soos
« Reply #2 on: February 03, 2007, 01:57:09 PM »
awesome....
I am interested in hearing how well this works out!!
l8r
-=≡ Soos ≡=-
(61mm)652cc 1979 cb650
Offline Soos
« Reply #3 on: April 01, 2007, 12:44:11 AM »
Soooo?
How did this go?
And is the Dyna S a step better than already exists stock on CB650's?
l8r
-=≡ Soos ≡=-
sfcb
« Reply #4 on: April 10, 2007, 03:11:18 PM »
well the dyna s works on my bike, but i think i need to swap out my coils for some 3ohm coils. when the bike is cold, i have to constantly play with the throttle.  but after it's warm (about a mile),  it runs great.
Offline Soos
« Reply #5 on: April 10, 2007, 05:03:46 PM »
I don't rember, are you running the stock airbox/filter?
-=≡ Soos ≡=-
sfcb
« Reply #6 on: April 16, 2007, 07:59:44 PM »
yup, all stock.  i'll probably get a fram a/f, but i took off the filter cover, and i just put large washers to hold the a/f in place.
