Author Topic: Wiring harness swapability from KO to K2 CB750 - what are the differences?  (Read 543 times)
Offline b1jackson
I have a K2 750 with a slightly hacked up harness.  A friend has a K0 harness that looks mainly the same however partzilla shows them as different and incompatible.
Is this just the clutch safety switch and/or signal light warning buzzer that is different between a K0 and K2 harness?
Any show stopping differences wiring wise (like the control switches) between a K0 and K2 harness.
Appreciate any insight.
Offline MauiK3
  • A K3 is saved
  • Old guy
I am not any sort of expert.
On my K3 I was having issues with my clutch safety switch so I just eliminated it. My harness was a K3 harness from Yamiya. Works well.
If the only issue is the clutch safety switch you may be able to work with it.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline Keith
The indicator lights are different, the K2 has a beeper cancel button, there are probably other differences. The K2 has quite s few one year only details.
Offline BPellerine
the ko had only one fuse,so there would be diff in the circuits I think,bill
1978 CB 750K ard and webers
another anfob
