Author Topic: CB750 Caliper Question  (Read 710 times)
Offline Yoshimitsuu
« on: August 27, 2019, 07:40:26 AM »
Good morning all,
I was looking into replacing the rotor on my 1974 CB750K4 to an EBC rotor but when I looked into it it was suggesting that I use a 77-78 caliper to accommodate it based on size. Would a 77-78 caliper fit on my current 74 caliper holder or would I have to buy the entire unit? Also, what should I be looking for to differentiate  between the two caliper holders? I’ve seen a few around the internet and they look almost identical to the 74 caliper holder. Thank you in advance!
Re: CB750 Caliper Question
« Reply #1 on: August 27, 2019, 08:36:58 AM »
The later caliper, mounts and fork slider are different from the early ones and as i dont do a lot of 750 i dont know when they changed
« Reply #2 on: August 27, 2019, 08:53:16 AM »
77 and 78 caliper and hanger will fit 73 to 76 750 forks.  The swing bracket is wider on the late calipers.
I think the piston is bigger, but keep in mind the hose inlet is at an angle, and solid lines look awkward. Many run  banjo fittings, myself I avoid banjo fittings,  I don't like the chunky look. If you make your own lines, you won't need them.
Offline Yoshimitsuu
« Reply #3 on: August 27, 2019, 09:23:39 AM »
Alright so I will continue searching for one. They look similar which has me worried that I’ll order one and then just get a K0-K6 caliper holder and waste my money. I’ve heard that the EBC rotor is an improvement in braking and I have made many of the other suggestions to the system like braided lines, modern master cylinder, new pads, etc. Thanks for the help!
« Reply #4 on: August 29, 2019, 11:39:03 PM »
Yosh, you need the smooth body caliper and it's matching arm, not the earlier finned caliper. These were used on the F0, F1, K7, and K8. They have a 42.8 mm piston, while the finned calipers have a 38 mm piston. Also, be aware that the 550 caliper is similar in appearance, but has a 38 mm piston, and can only be used with a 550 diameter rotor.
Offline Doobie
« Reply #5 on: August 30, 2019, 03:06:27 AM »
From what I've read on sites that sell these rotors, the EBC Vintage Rotor VMD3019 is a direct replacement for the 76 CB750K and earlier. The EBC Pro-Lite MD1062LS will fit if you use the 75-76 750F or 77-78 CB750K caliper and bracket.
You only go around once in life so it might as well be on a motorcycle.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
